Missing piece/part?
Forum topic by randywarner posted 04-14-2014 01:11 AM 1037 views 0 times favorited 5 replies Add to Favorites Watch
View randywarner's profile
randywarner
4 posts in 2026 days
04-14-2014 01:11 AM
Topic tags/keywords: table saw missing piece part help tablesaw
Please help. See the image above. The threaded “cap” on the end of the shaft that turns to raise and lower my blade won’t spin with the shaft. I noticed this when I went to put the blade down so I opened the cabinet to inspect inside. I started by vacuuming up the sawdust and think it may have vacuumed up a part. There are two holes on either side of the threaded cap as though something is missing. If I am missing something can anyone identify what I’m missing. See the attached picture. Also, the link to the parts diagram is below but I can’t make out what it is I would be missing. It is a Craftsman, model number152221140. Thanks.
http://c.searspartsdirect.com/lis_png/PLDM/P0607067-00002.png
5 replies so far
View crank49's profile
crank49
4032 posts in 3209 days
#1 posted 04-14-2014 01:54 AM
There should be a set screw or roll pin, probably the later, in that hole.
If it is a roll pin there has to be a matching hole through the shaft inside the screw threaded “cap”.
randywarner
#2 posted 04-14-2014 02:18 AM
Thanks crank49. There isn’t a hole in the shaft and the holes in the threaded screw cap don’t appear to be threaded.
crank49
#3 posted 04-14-2014 02:32 AM
If the holes are not threaded the only way the cap could be tied to the shaft would be a pin.
It is possible the cap part has shifted along the length of the shaft so that now you can’t see the hole.
Something has to attach the screw threaded cap to the shaft somewhere.
And two holes in the cap strongly suggests it was something that passes through from one side to the other.
View tefinn's profile
tefinn
1222 posts in 2675 days
#4 posted 04-14-2014 02:55 AM
crank49 is correct. It’s part no. 244 on the diagram. Your shaft has probably shifted so the holes don’t line up. You may have to do some dis-assembly to get it lined up again.
-- Tom Finnigan - Measures? We don't need no stinking measures! - Hmm, maybe thats why my project pieces don't fit.
View Ted's profile
Ted
2875 posts in 2449 days
#5 posted 04-14-2014 03:11 AM
Fish around the dust in your vac with a strong magnet, you might find the part.
-- You can collect dust or you can make dust. I choose to make it.
