Cutting plywood
Forum topic by Coleby posted 04-13-2014 08:21 AM 1538 views 0 times favorited 9 replies Add to Favorites Watch
View Coleby's profile
Coleby
29 posts in 2876 days
04-13-2014 08:21 AM
Topic tags/keywords: question router shaping arts and crafts
I want to build multiple car shaped beds for the familiy. I have a template for the side profile and want to know if there is a safe affective way to simply lay the template on top and use a router to cut the shape in one pass. Its 3/4” birch. I want to avoid using a jig saw and then flush trimming. This would save me an significant amount of time but what are my Options??
Thanks
Jonathan Dean
-- Dean, http://www.woodworkerColeby.com
9 replies so far
View Whiskers's profile
Whiskers
389 posts in 2113 days
#1 posted 04-13-2014 01:14 PM
Yeah, this one is easy, you want a pattern bit. A pattern bit is a straight bit that has a bearing on the top or bottom that rides along another piece you do not want to trim, and cuts the part above or below it. Be sure to put a little light oil on the bearing before starting. Just use a jig saw to sloppily rough cut your sides a little larger than you want. Clamp or screw your template to it, than go at it with the router to trim it. Tricky part is getting that first piece cut just right and perfect to be the pattern. One way to approach that problem is to cut as close as feasible with your jig saw, being extremely careful not to undercut anything, overcutting a little is allowable. Than use a oscillating spindle sander to sand the edges into final shape. Much easier to sand to a line on a sander than to cut to one with a jig or band saw.
View JesseTutt's profile
JesseTutt
854 posts in 2197 days
#2 posted 04-13-2014 01:31 PM
Make sure you attach the pattern piece to the plywood to be cut. Screw it in areas that will be cut away or use double sided tape, or both.
If you mean that the pattern is a piece of paper, then attach the pattern to a piece of 1/2 inch plywood and cut and sand the plywood to be the correct shape and then adhear the plywood to the wood to be cut.
View Lee Barker's profile
Lee Barker
2170 posts in 2937 days
#3 posted 04-13-2014 03:18 PM
You won’t cut the 3/4 birch in one pass. Probably about 5. It’s still a great way to get what you want.
You’ll need:
A middle line router
A 1/2” shank top bearing bit
A sacrificial piece of something underneath…
And a large container for the chips!
Kindly,
Shawn Masterson
1325 posts in 2035 days
#4 posted 04-13-2014 04:13 PM
spot on lee I would say 4-5 passes. On the other hand with an good saber saw blade you could cut it within an 1/8” of the line and just flush trim it in 1 pass. I think the saber saw and flush trim will be faster with a cleaner end product.
View ChefHDAN's profile
ChefHDAN
1101 posts in 2936 days
#5 posted 04-13-2014 04:26 PM
Coleby, Lee is right on the money, with the how too, but if you’re looking to save time, then the jigsaw cut and flush trim is the fastest method since you can flush trim in 1 pass if you’re just cleaning up an 1/8” off the edge, and you’ll have alot less mess to as Lee points out.
View NiteWalker's profile
NiteWalker
2737 posts in 2663 days
#6 posted 04-14-2014 04:59 AM
”I want to avoid using a jig saw and then flush trimming.”
You’d lose any time saved not sawing close to the line from having to take multiple passes as Lee mentioned.
Jigsawing close to the line, then flush trimming is the fastest method.
View JaySybrandy's profile
JaySybrandy
78 posts in 1663 days
#7 posted 04-14-2014 09:10 AM
how many are you going to make because I would just jig saw the flush trim in needed to
View Jim Finn's profile
Jim Finn
2666 posts in 3008 days
#8 posted 04-14-2014 03:08 PM
I would saw it then rout also. I would use a hand held jig saw with a metal cutting blade to reduce the amount of splinters caused by this cut.
-- No PHD just a DD214 and a GED Website> https://craftingcouple.com
View bigblockyeti's profile
bigblockyeti
5170 posts in 1807 days
#9 posted 04-14-2014 04:13 PM
I cut 3/4” plywood in three passes before and wouldn’t recommend doing it with any less. This was also done with a 3/8” bottom bearing bit so only 3/8” is being removed and the bit is not necked down between the router and the cutting edges increasing the chance of a broken bit when being overfeed. Precutting with a bandsaw or jigsaw and doing a final trim with a bit would greatly reduce not only the mess, but the strain put on the router and cutting bit.
