Draw knife versus scrub plane
« back to Hand Tools forum
Forum topic by JohnChung posted 04-12-2014 11:42 AM 2649 views 0 times favorited 6 replies Add to Favorites Watch
View JohnChung's profile
401 posts in 2007 days
04-12-2014 11:42 AM
There are a few uses that a scrub plane rules.
1) Making scallop texture
2) leveling the board. A jack plane with a chamber plane has a similar effect.
3) General dimensioning.
However a drawknife will outperform a scrub plane when remove the width of the board when it attacks from the edge of the board. The drawknife can remove a lot of material off and still have a control cut. It can produce fine shavings.
Other common uses of drawknife are:
1) remove bark.
2) initial dimensioning of chair or table legs.
Please contribute your uses of the drawknife and scrub plane
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3645 days
#1 posted 04-13-2014 02:55 AM
I’ve never used either…they strike me as tools for very different applications though.
#2 posted 04-13-2014 10:15 AM
In most cases yes as both tools function very differently.
I really need to make a video on this subject and compare both speeds on the edge.
Once I have it done I will post it up.
Here is the drawknife in action:
View theoldfart's profile
9496 posts in 2383 days
#3 posted 04-13-2014 02:22 PM
John, i have used my 40 1/2 on board edges on a number of occasions with great success. I set it for a very thick cut and can take a 1/4 to 1/2 ” off quickly. I have been considering getting a draw knife for putting cambers on corners of bench post and the like.
-- "With every tool obtained, there is another that is needed" DonW ( Kevin )
#4 posted 04-13-2014 03:00 PM
@theoldfart – try using the draw knife in place of 40 1/2. The speed for the edge is amazing. The only drawback is the long sharp edge and don’t use too much force as it can be dangerous. Chamber on bench post, a draw knife can do it very easily.
Here is what a draw knife can excel at:
I am still keeping my scrub plane. There are other uses which the draw knife can’t substitute.
View bigblockyeti's profile (online now)
5051 posts in 1653 days
#5 posted 04-13-2014 03:04 PM
I’m looking for a drawknife right now and will be using it mostly for removing bark, possibly some defect removal.
#6 posted 04-13-2014 06:41 PM
