How to keep ca glue bottle top from sticking?
« back to Woodturning forum
Forum topic by Split posted 04-12-2014 06:51 AM 1816 views 0 times favorited 8 replies Add to Favorites Watch
View Split's profile
Split
33 posts in 1765 days
04-12-2014 06:51 AM
I know this sounds stupid however I finish all my turnings with ca glue and every time I am finished with the glue I wipe the novel as well as I can with a paper towel and place the top on. I then keep it vertical for storage but latly I have had difficulty removing the top. Has anyone had this problem or have a solution for it?
Thanks
8 replies so far
View Purrmaster's profile
Purrmaster
915 posts in 2119 days
#1 posted 04-12-2014 07:52 AM
It doesn’t sound stupid and I run into the same things. One thing you can try is to put a dab of super glue remover (it’s basically a gel with acetone in it) on the tip or inside the cap and close it up.
View rustfever's profile
rustfever
752 posts in 3336 days
#2 posted 04-12-2014 08:41 AM
Wipe the bottle tip BEFORE replacing the cap is effective.
-- Rustfever, Central California
View MalcolmLaurel's profile
MalcolmLaurel
298 posts in 1649 days
#3 posted 04-12-2014 11:53 AM
Simple… don’t use the cap! CA doesn’t “dry” with exposure to air, so there’s no need to cap it.
The best thing I’ve found for CA is to get some very small teflon capillary tubing and stick a piece (about 1” long) into the bottle’s nozzle. This allows you to dispense a tiny bit as needed. When you’re done, tap the bottle on the bench a couple of times and most of the glue will run back down the tube again. If it does clog, you can usually just pull the clog off of the end of the tube and failing that, snip a tiny bit off the tube.
If you must cap it, don’t use the supplied cap but instead use a pin or thumbtack inside the nozzle. This keeps the hole clear.
-- Malcolm Laurel - http://MalcolmLaurel.com
View RobynHoodridge's profile
RobynHoodridge
127 posts in 2355 days
#4 posted 04-12-2014 12:17 PM
MalcolmLaurel said some good things. But one thing he said is problematic. CA glue should not be left open.
True, it doesn’t “dry” like some abrasives by evaporation of a solvent. But it does set. And the chemical reaction for this setting is reaction with water, usually water vapour in the air, or natural water content of what you’re gluing. I think you can see where this is going. So restrict the glue’s access to the atmosphere as much as possible.
-- Never is longer than forever.
View Gene Howe's profile
Gene Howe
10535 posts in 3454 days
#5 posted 04-12-2014 01:23 PM
Lately, I’ve been buying CA made by Loctite. It seems that their cap system won’t allow for it to be glued to the spout.
I don’t understand why. I just gratefully accept it.
View crank49's profile
crank49
4032 posts in 2997 days
#6 posted 04-12-2014 03:40 PM
The caps that work well and usually don’t stick have a little stainless needle inside that goes into the nozzle and plugs it from the inside.
View Woodknack's profile
Woodknack
11792 posts in 2406 days
#7 posted 04-15-2014 04:28 AM
Loctite Pro, best superglue I’ve ever used and the cap doesn’t stick
http://lumberjocks.com/reviews/3530
View Rick's profile
Rick
9728 posts in 3058 days
#8 posted 04-15-2014 06:33 AM
Rick:
The first one I bought (Identical to your review) had the Name Loctite on it.
It came (still does) it’s own Plastic Bottle. The name has now been changed to LePage. (Canada)
Maybe they bought them out or something. They also have a Gel. NOPE! Liquid is much better.
TOP? On or OFF. Zip! Zap! No Clog!
As You said at $7 or $8 a bottle and 20 ml. it’s also the best deal out there.
Actually I used it twice today. Once to fasten, and once to Repair a Break I Made!
FOR SHAME RICHARD!!! ....LOL..
EDIT: Although the Wording below on HD still says “Loc Tite Pro” at $8.47 this is the picture they show.
-- LIFE is what happens when you're planning on doing Other Things!
