Spray painting a hand plane
« back to Hand Tools forum
Forum topic by ajthomas5009 posted 04-11-2014 11:47 PM 1354 views 0 times favorited 4 replies Add to Favorites Watch
View ajthomas5009's profile
ajthomas5009
296 posts in 1855 days
04-11-2014 11:47 PM
I’m spray painting a hand plane with SW alkyd / oil rust inhibiting spray. Since I suck at spraying I’ve decided on several light coats to prevent drips. So far I have 3 coats on. The first was very light. The second slightly heavier and I kept the 3rd coat the same as the second. I’ve been waiting 15 – 30 mins between coats. How many coats are suggested for a durable finish? I was thinking 5-7 but which seems like it could be overkill but this is my first handplane resto. The faster my fellow LJ’s can respond the better since I’m currently painting ;-)
-- Sometimes you're flush and sometimes you're bust, and when you're up, it's never as good as it seems, and when you're down, you never think you'll be up again, but life goes on.
View Tim's profile
Tim
3812 posts in 2199 days
#1 posted 04-12-2014 12:03 AM
I haven’t sprayed any, I leave mine as is so far, but in order to get you a quick answer, my recollection of the process is to actually do a thick coat so it pools a bit and when it dries it looks more like the original japanning. I think the idea is to get it just short of where it will run and sag.
ajthomas5009
#2 posted 04-12-2014 03:16 AM
Well I ended up sticking with the multiple light coat method, 6 to be exact. I have the worst trouble with sagging and drips when ever I try to spray any thicker. By the time I was done spraying the paint was thick enough to mask the casting bumps on the flat surfaces. It seemed to turn out well so far but I won’t really know until tomorrow.
I know a week is the suggested curing time so I’m assuming that applies to reassembly and use, or just use? Also how long should I wait to unmask the machined surfaces?
View Tim's profile
Tim
#3 posted 04-13-2014 01:39 AM
Sorry, no idea. You might have better luck in the Handplane of your dreams or Show the restoration before and after thread.
View WoodAndShop's profile
WoodAndShop
149 posts in 1747 days
#4 posted 04-17-2014 01:31 AM
What part of your plane were you spraying? The bed? I simply use engine enamel primer and black engine enamel paint…only one coat of each. That was plenty, and had no trouble or dripping. Just make sure you tape off the parts that shouldn’t be painted. Give it a try!
-- Joshua Farnsworth - Free Traditional Hand Tool Woodworking Tutorials: http://WoodAndShop.com
