Variable Speed for a Random Orbit Sander
Forum topic by paxorion posted 04-11-2014 06:43 PM 1539 views 0 times favorited 13 replies Add to Favorites Watch
View paxorion's profile
paxorion
1107 posts in 2011 days
04-11-2014 06:43 PM
Topic tags/keywords: question sander
I was wondering if other LJs can shed light on a question has been burning on my mind for a few months. What is the practical use of variable speed for a 5” random orbit disc sander in woodworking. Is it useful for woodworking? If so, when would one take advantage of the lower speeds?
-- paxorion
13 replies so far
View NiteWalker's profile
NiteWalker
2736 posts in 2543 days
#1 posted 04-11-2014 08:50 PM
I never use the vs on my ros.
View woodchuckerNJ's profile
woodchuckerNJ
1269 posts in 1600 days
#2 posted 04-11-2014 08:56 PM
I have a porter cable, it’s not variable speed. But I attach a speed control on occasion.
Actually I hardly use an ROS anymore.
But when doing delicate work, I found the speed too much.
There are times when I just wanted to just take the fuzz off.
I now use a Bosch 1/4 sheet sander for that. It does a better job in general, but it eats paper. The ROS doesn’t. So if I didn’t have the 1/4sheet I would use the speed control more often when wanting to do verticals, delicate work…
It just give me that little more control.
-- Jeff NJ
View PaulDoug's profile
PaulDoug
1510 posts in 1669 days
#3 posted 04-11-2014 11:33 PM
I have one and can’t remember a time I changed the speed. Not saying I haven’t but it would have been so rare that if there was a big price difference, I wouldn’t but one with speed control.
View dawsonbob's profile
dawsonbob
2820 posts in 1721 days
#4 posted 04-11-2014 11:38 PM
My Bosch has variable speed but, come to think about it, I’ve only turned the speed down once or twice. I have to agree with PaulDoug in that, if there were a big price difference, I’d probably buy the single speed one.
-- Mistakes are what pave the road to perfection
View AnonymousRequest's profile
AnonymousRequest
861 posts in 1515 days
#5 posted 04-12-2014 01:29 AM
I have an older 6” Porter Cable. The slower speed will give you more control at times. That is useful for what I do.
View jmartel's profile
jmartel
7806 posts in 2116 days
#6 posted 04-12-2014 01:38 AM
I change the speed on mine. High speed for initial sanding, lower speed for final sanding and more delicate work.
View pintodeluxe's profile
pintodeluxe
5620 posts in 2779 days
#7 posted 04-12-2014 02:20 AM
I use variable speed for edge sanding, or for smaller parts. It is easier to control, and gives you more options. My Bosch has variable speed, but it is underpowered anyways. I wish my Dewalt had variable speed.
View bigblockyeti's profile
bigblockyeti
5094 posts in 1686 days
#8 posted 04-12-2014 02:26 AM
I have a right angle Porter Cable and I have used it with very fine sandpaper sanding really small stuff where maximum control and minimum material removal is needed.
View stnich's profile
stnich
118 posts in 2890 days
#9 posted 04-12-2014 01:13 PM
I have four RO sanders. One does not have variable speed which I keep 60 grit paper on it for
hogging off a lot of material. The three others have 80-100-120 grit papers. Since they are used for
different applications they are at different speeds. And I do adjust the speed depending on the wood
I’m sanding. One advantage to have multiple sanders is that I don’t have to constantly change the sandpaper
which decreases the life of the hook and loop pads.
View Jim Finn's profile
Jim Finn
2647 posts in 2888 days
#10 posted 04-12-2014 04:06 PM
I have the porter cable variable speed sander also and use the slower speeds for sanding very small or delicate parts.
-- Website is https://craftingcouple.com/
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3551 days
#11 posted 04-12-2014 07:44 PM
Yes much more overal control when sanding smaller delicate stuff, mouldings etc . Alistair ps I do use mine a lot
paxorion
#12 posted 04-13-2014 02:58 AM
Hmm fascinating, so it sounds like the majority of people find variable speed helpful when sanding…
  1. delicate surfaces parts/curves
  2. different woods (lower speed for softer wood?), for better control over sanding rate
Also I’m not in the market for a new sander, but rather just a question of hypothetical benefits/practical uses of variable speed. Thanks everyone for sharing…
-- paxorion
View dirtycurty's profile
dirtycurty
44 posts in 1544 days
#13 posted 04-14-2014 10:17 PM
woodchucker, have you tried using a spray adhesive on your sanding pad of your 1/4 sheet sander? I have never done it myself, I don’t even own one, but I have read other forums saying that it really helps to keep your paper from tearing up and binding.
