Band Saw Question
Forum topic by CharlieM1958 posted 04-11-2014 03:57 AM 1330 views 1 time favorited 12 replies Add to Favorites Watch
16281 posts in 4459 days
04-11-2014 03:57 AM
I need a little advice with a new-to-me Sears 12” band saw.
The saw belonged to ny dad, who is in a nursing home now, and it has not been used in quite a while. In the process of cleaning it up, I noticed the blade was too close to the edge of the tire on the top wheel. When I loosened the tension knob to fiddle with the blade, nothing happened. I loosened it all the way, but the top wheel never moved, and the blade was still as taut as ever.
I’m guessing something is just gummed up, but I’m not sure of the best way to proceed. Would tapping the upper wheel with a rubber mallet make any sense, or is there a better way?
12 replies so far
35154 posts in 4641 days
#1 posted 04-11-2014 04:26 AM
If I remember correctly Charlie, The upper wheel carriage rides on a couple of steel rods. everything shouldslide up and down freely. try a lottle wd40 to loosen everything up.
-- I've been blessed with a father who liked to tinker in wood, and a wife who lets me tinker in wood. Appomattox Virginia karsonwm@gmail.com †
CanadianWoodChuck
402 posts in 4154 days
#2 posted 04-11-2014 04:33 AM
Charlie
Here’s a link to a video done by Michael Fortune on Fine Woodworking that gives you the basics for a bandsaw tune-up http://www.finewoodworking.com/tool-guide/video/how-to-set-up-a-bandsaw.aspx
-- Wood Chuck (Bruce) http://3dwoodworkingplans.com
View Magnum's profile
Magnum
10935 posts in 3273 days
#3 posted 04-11-2014 07:51 AM
Charlie:
If you have a Model # I’d be pleased to see what I can find for you. By PM would probably be best.
Rick
-- Made In Ontario, CANADA
View SPalm's profile
SPalm
5326 posts in 4123 days
#4 posted 04-11-2014 11:36 AM
I believe it is frozen, as in any mechanical part can freeze from oxidation. So I would think a little nudging with a mallet along with some spray lube would be called for.
Steve
-- -- I'm no rocket surgeon
#5 posted 04-11-2014 12:32 PM
Yep, a little spray and a couple of light taps did the trick. I just thought I’d run it by the group before I did something stupid. Now it’s on to the full tune-up.
Thanks for the help, Guys.
Bruce: Thanks for the link.
View Porchfish's profile
Porchfish
847 posts in 2773 days
#6 posted 04-11-2014 02:44 PM
Smack away !
-- The pig caught under the fence is always the one doing all the squealing !
View bigblockyeti's profile
bigblockyeti
5319 posts in 1961 days
#7 posted 04-11-2014 02:50 PM
If the blade has been under any significant level of tension for an extended period of time, might be a good idea to check the tires for indentations as they can be quite infuriating when trying to isolate the source of vibration on an older saw.
View distrbd's profile
distrbd
2252 posts in 2687 days
#8 posted 04-11-2014 03:05 PM
Charlie,I hope your dad settles nicely in the nursing home .
-- Ken from Ontario, Canada
View cajunpen's profile
cajunpen
14578 posts in 4306 days
#9 posted 04-11-2014 04:01 PM
Charlie I’ve always said that a good whack with a hammer will fix most anything :-). Hope you enjoy using your Dad’s bandsaw.
Magnum
#10 posted 04-11-2014 11:47 PM
Charlie:
Thanks for the PM. Glad you’re on your way now.
I Second what Ken (Very Nice Guy) said about your Dad.
I went through the same thing with My Mom a couple of years ago. It can sometimes not be a Pleasant Experience. For me it was a 24 Hour a Day “Watchdog” thing.
BUT! Your MOM is Your MOM. You do what you have to do and you do it with Love In Your Heart.
Regards: Rick
View NormG's profile
NormG
6378 posts in 3244 days
#11 posted 04-12-2014 12:00 AM
I would suggest that ou now use dry lube of some type, to eliminate the smell of WD40 and the possibility of staining your project
-- Norman - I never never make a mistake, I just change the design.
#12 posted 04-12-2014 12:29 AM
Thanks for the kind thoughts.
Dad’s mind is pretty well gone, but at least he is relatively serene and free of pain, so I’m grateful for that.
