« back to Coffee Lounge forum
Forum topic by . posted 01-12-2009 09:47 PM 1173 views 0 times favorited 3 replies Add to Favorites Watch
View .'s profile
76 posts in 3760 days
01-12-2009 09:47 PM
3 replies so far
View PurpLev's profile
PurpLev
8534 posts in 3611 days
#1 posted 01-12-2009 10:37 PM
230/220 is pretty much the same, older breakers used to be 230, newer ones are 220, motors wired for 230/220 are identical and will work on either – this is the equivalent to the US 110/120 circuits…
View Woodchuck1957's profile
Woodchuck1957
944 posts in 3727 days
#2 posted 01-13-2009 12:18 AM
I’m not sure if I understand you correctly, you want to run the DC and another piece of equipment at the same time off the same 220/230 breaker ? if so, it’s probably not doable, I doubt that 30 amps is enough. You should really have a seperate 220/230 circuit for the DC. Even a dedicated 110/115 circuit would work.
View pitchnsplinters's profile
pitchnsplinters
262 posts in 3401 days
#3 posted 01-13-2009 01:48 AM
Check out pages 19 & 20 in the Manual (http://content.jettools.com/manuals/708636K_man.pdf).
Looks pretty straight forward. I’m sure it will be obvious once you take the cover off your control unit / motor.
Your tool will know no difference between 220 & 230 V. I bet if you check your voltage with a volt meter it will be neither 220 or 230 but somewhere in the vicinity.
-- Just 'cause a cat has kittens in the oven, it don't make 'em biscuits.
