| Forum topic by mtnbikecrash | posted 319 days ago | 187 views | 0 times favorited | 12 replies | ![]() |
319 days ago |
Topic tags/keywords: lead dust lead poisoning refinishing sanding dust collection refurbishing Are there any lumberjocks who have experience with lead based paints/finishes and the removal of such materials? Unfortunately I goofed and started sanding on an old dresser before I remembered to test the finish for lead. After sanding on it for about an hour I realized this and went and got a lead test kit. Well CRAP, it was positive for lead and I now have the dust all in my sander, dust collector, and on the floor. I have since “wet” cleaned everything exposed. I guess my question the jocks is how harmful is this stuff and should I be worried about the possibility of ingestion and the effects of lead poisoning. Any knowledge you guys have is well appreciated. -- JD - Sand Springs, OK - "You can't steer a car that isn't moving..." Unknown |
319 days ago |
hey , i ate a lot of paint chips when i was a kid and i turned out ok ! lol lol sorry i had to do that . fact is im not qualified to answer your question , i think it depends on how much you ingest . were you wearing a dust mask ? id certainly do a good cleanup of you dust collector and sander ect . |
319 days ago |
I wonder if you might find a better answer from your medcal team. I think the wine maybe washed it all away. ;-)...Maybe not, do I sound like Ceasar? -- A mind, like a home, is furnished by its owner |
319 days ago |
ha ! i knew that was your real pic in your avatar bob ! lol id say good advice . as an adult it would take a lot more exposeure than a child . its ironic that osha has people walking around in space suits removeing old paint but its quite ok to pull off your helmet and go have a smoke break every 15 minutes ! lol |
319 days ago |
Osha, like all goverment agencies is operated by pygimies. Bob -- A mind, like a home, is furnished by its owner |
319 days ago |
Sounds like you didn’t take in to much but better to play safe, you might want to check with you Dr. As far as more removal, If you are going to continue you must wear a HEPA mask and clean with a HEPA vac. and tyvek suit. It depends on your location how you handle the waste. You can check with your local town for the codes if you want to go that way. I had my own air filtration co. so I am familiar with that end. Good luck. mrtrim, The cabinets look great! sorry I can’t say the same for you. Stay away from the lead!! he,he :-) -- Bob K. East Northport, NY |
319 days ago |
bob 42 , i know where you live , im packin my sawsall ! lol |
319 days ago |
mrtrim, :-o oh no!! -- Bob K. East Northport, NY |
319 days ago |
A friend of mine was stripping some siding (outside) with a heat gun, It was lead paint and He got sick from the lead being heated and inhailing, he felt sick, went to DR and it was in his blood. -- MARK IN BOB, So. CAL |
319 days ago |
ever put a pencil in your mouth…................that was made off shore, surely theres no lead in the paint, or the pencil, or that new christmas ornament the baby is sucking on? ever pulled the coating off an electrical wire…...............and used your teeth to pick it off….....I hear there can be lead in the plastic sleave? they used to use PCB’s and DDT’s in paint too???...or maybe it was engine oil…......and even hair spray? I’ld be worried. Maybe thats my problem…..................too much lead in my life? |
319 days ago |
seriously….....................work smart and if in doubt, get it checked out, |
318 days ago |
your more likely to get poisoned driving in traffic every day than from one exposure to dust. It takes some time for it to build up in your body to dangerous levels, but by all means get yourself checked out if you want but dont start changing your last will and testament just yet. I worked with recycled wood for years and my levels, although high, are still within the safe zone. I would have been clear except i was young and foolish and didn,t take precautions. At least you have a test kit and a better awareness than I had so I sugest crack open a cold one and light up a stogie, it ain,t a death sentence. -- if the hand is not working it is not a pure hand |
318 days ago |
Thanks for the words everyone. I do like the last suggestion though, except for the stogie part; I’m not much of a smoker. I have an appointment for this morning to get a lead blood test performed. So you can remove lead base paint safely using a non-toxic stripper and a good respirator? At least that is what I am gathering. I guess the key is to keep the stuff wet so it doesn’t dust up, keep it out of my lungs and off my skin and then properly dispose of it? Thanks guys… JD -- JD - Sand Springs, OK - "You can't steer a car that isn't moving..." Unknown |
| Forum | Topics |
Woodworking Skill Share
2924 |
3954 |
257 |
952 |
225 |
Woodworking Trade & Swap
621 |
Coffee Lounge
2396 |
LumberJocks.com Site Feedback
524 |
