Question concerning type of glue recommended for maple top workbench
« back to Joinery forum
Forum topic by NormLz posted 04-10-2014 01:32 AM 925 views 0 times favorited 5 replies Add to Favorites Watch
View NormLz's profile
NormLz
29 posts in 1462 days
04-10-2014 01:32 AM
Topic tags/keywords: question maple joining
I’m in the process of designing my new work bench. I’ve created a Sketchup drawing of my new workbench which combines a standard maple top bench with the Festool MFT-3 bench. Over the years I have used many different types of wood glues but I would like to know if there is a recommended glue for the maple top? By the way I still have some changes to make to my drawing. Hopefully the drawing will be done in a couple of weeks. I bought a Lie-Neilsen end vise to add to the bench which also has to be added to the drawing. Hopefully someone will be able to advise me on a Glue selection for my new bench.
-- Norm, Connecticut
5 replies so far
View woodchuckerNJ's profile
woodchuckerNJ
1251 posts in 1509 days
#1 posted 04-10-2014 01:38 AM
Either yellow or white glue.
I built mine with yellow, but I was rushed, I have since started using elmers for having a longer working time when doing large glue ups. Frank Klausz always seems to use Elmers white.. so I took the hint, and it really does give you a bit more time. But you can also get the same from Titebond type 3 which has a longer working time.
-- Jeff NJ
View waho6o9's profile
waho6o9
8070 posts in 2452 days
#2 posted 04-10-2014 01:42 AM
Titebond 3 works well. There’s a date code on it and using it
within the year’s shelf life is optimal.
View Ted's profile
Ted
2838 posts in 2086 days
#3 posted 04-10-2014 01:57 AM
I’m a Titebond fan, II for shorter clamp time and III for longer working time.
-- You can collect dust or you can make dust. I choose to make it.
View redSLED's profile
redSLED
790 posts in 1767 days
#4 posted 04-10-2014 02:52 AM
Another vote for Titebond III. Nice sketchup job.
View crank49's profile
crank49
4028 posts in 2846 days
#5 posted 04-10-2014 05:06 AM
Titebond III here.
The Schwarz would not approve of your design, I don’t think, but if it works for you….
