Home made veneer softener recipe
Forum topic by higtron posted 04-09-2014 07:21 PM 2595 views 0 times favorited 4 replies Add to Favorites Watch
View higtron's profile
higtron
237 posts in 2706 days
04-09-2014 07:21 PM
Does anyone have a tried and, true recipe for veneer softener thanks in advance for any responses.
-- A friend will help you move, a good friend will help you move a body
View Loren's profile
10476 posts in 3677 days
#1 posted 04-09-2014 07:22 PM
Glycerin and water is one that works. If you can find somebody
who makes biodiesel they will have glycerin and may give
it to you since it’s a waste byproduct of making the fuel.
View shipwright's profile
shipwright
7996 posts in 2827 days
#2 posted 04-09-2014 11:40 PM
Water is all you need.
Spray your veneer to get it to relax and soften up.
Press it between several sheets of newsprint.
Change the paper every several hours until the veneer is flat and dry.
Hot cauls will speed the process. They can be very hot (250 to 300 degrees F)
Why introduce chemicals when you don’t have to?
#3 posted 04-10-2014 12:40 AM
That’s good to know, Paul. I’ve done a little veneering
in the past and am in the process of getting set up to
do it much more seriously.
shipwright
#4 posted 04-10-2014 12:43 AM
Loren there is a very good section on veneer preparation in Pierre Ramond’s “Marquetry” that covers the use of hot cauls.
