help with purple heartwood finish
Forum topic by Peloton posted 320 days ago 783 views 0 times favorited 5 replies Add to Favorites Watch
View Peloton's profile
Peloton
27 posts in 334 days
320 days ago
Topic tags/keywords: finish help
For Christmas this year I made some boxes. The problem is; ok, there were lots of problems, but this particular problem is that after finishing the boxes, the purple heartwood was more brown heartwood.
I tried a couple different finishes. I used “natural” minwax with a coat of gloss polyurethae and I tried Tung oil.
Can anyone suggest a finish that will bring out or at least not mute the purple of the wood?
Any help would be greatly appreciated.
Lance
-- “I'm thinking about it, ... I'm thinking it's the best way to piss [the French] off.” -Lance Armstrong
View HokieMojo's profile
HokieMojo
1142 posts in 627 days
320 days ago
i think freshly cut, purple heart will turn brown. then leaving it exposed to air, it will go back to purple. then if it is exposed to light to long, it will end up a purplish brown. I can’t be certain (you would think with so many people using PH, there wouldn’t be so many myths floating around about it). I bought my first piece a few weeks ago. At some point, I’ll try it out on simething to see what happens. Hopefully someone else can contribute more than me.
View jnimz's profile
jnimz
36 posts in 325 days
320 days ago
Purpleheart ages to a brownish color regardless of what you do, in my experience. The best finish I’ve found for preserving the purple color is mineral oil.
-- Jace - http://rumplestiltskeins.etsy.com - http://www.lessthanunder.com - http://www.shopsmith.com --
View Waldschrat's profile
Waldschrat
340 posts in 334 days
320 days ago
I agree with jnimz, I have also had Purpleheart in the hand a few times (mainly knife making or woodturnings) and it always seem to turn a brownish color. I think that is just the way it is with alot of woods, they seem just to turn brown when starting out a reddish color (especially tropical woods). Same thing with plum wood.. it starts the most beautiful wood out of the planer, but after a year or sometimes less with sunlight it is just brown, still really pretty but browns and reddish browns.
I do not know about mineral oil… sounds good I will have to give it a shot
-- Nicholas, Journeyman Cabinetmaker, Partenkirchen, Germany
View mmh's profile
mmh
1410 posts in 621 days
320 days ago
I have tried using the Waterlox Marine quality polyeurethane/oil finish to see if the UV inhibitors will help keep the color of fancy woods brighter. It’s very costly ($30./qt.)and has toxic fumes, although there’s a new low VOC formula. This seems to have helped a bit, as I’ve had to re-finish a Pink Ivory & Purpleheart cane that was finished with tung oil that allowed them both turn brown. This photos is with the original tung oil finish before it darkened: http://lumberjocks.com/projects/11812 . I’ve used this also on other bright fancy woods but I haven’t had these pieces long enough to tell if this formula really helps http://lumberjocks.com/projects/11578 .
Peloton
319 days ago
Thanks for the comments. My next project also involves purple heartwood and I’ll try some of the suggestions above.
