A precision fence for my Shopsmith
Forum topic by Gene Howe posted 04-08-2014 10:58 PM 3506 views 4 times favorited 13 replies Add to Favorites Watch
View Gene Howe's profile
Gene Howe
10349 posts in 3392 days
04-08-2014 10:58 PM
Topic tags/keywords: jig
I know that most people here on LJs are not Shopsmith users, but some one might get an idea for another application. Besides, I wanted to show off my little jig. I’m sorta proud of it.
The Jointech fence and router table attached to my MK5 is an absolute joy to use….as long as frequent table height adjustments are not needed. (as in dadoing) So when I was offered a reconditioned shorty I couldn’t pass it up.
With the shorty, all the capabilities of the MK5 are once again available.(except the lathe…No biggie, I don’t turn)
I guess the Jointech’s precision spoiled me because I found the stock fence on the shorty a bit on the imprecise side of accurate adjustment. So, when I stumbled on an old Incra fence system I had used on a router table I cobbled together many years ago, a light went on. I’ll make my own Incra fence.
Here are a few pics of my new Incra table saw fence.
A pair of Incra jigs attached to a piece of 3/4 BB for fine adjustment. A pair of T tracks and inserts on the under side of the jigs for gross adjustment. Metal clamps to hold the gross setting.
A view under the auxiliary table showing the table clamp system. Actually two joined tables.
Before clamping the jig to the table the fence is extended to register it against the blade.
Registered. Now the table clamps can be tightened.
Then the fence can be pulled back. In this case, a bit farther than necessary. And the metal clamps are closed to hold the gross adjustment.
Finally, the Incra jigs are adjusted to the precise measurement needed.
It took much longer to type this than it takes to set up the fence.
In just 2-3 minutes I can be dadoing, grooving or cutting.
Thanks for looking and all comments are welcome.
13 replies so far
View JL7's profile
JL7
8644 posts in 2929 days
#1 posted 04-08-2014 11:25 PM
Very cool Gene…..just don’t stick your fingers under the table when the saw is spinning…...! That’s a great setup….enjoy it…..
-- Jeff .... Minnesota, USA
View Jerry's profile
Jerry
2612 posts in 1612 days
#2 posted 04-08-2014 11:35 PM
Fantastic! I’m very jealous. I’m just now recovering from the damage my innacurate shopsmith fence did to my latest project. Word to the wise, check that it’s perfectly perpendicular to the table as well. Mine wasn’t because the piece I was ripping was wide enough that I had to attach the fence to the outrigger leg, like yours is. That was enough to mess up the parallel alignment ( which I DID check ) AND the vertical alignment, ( which I totally overlooked until it hosed me ).
-- There are good ships and there are wood ships, the ships that sail the sea, but the best ships are friendships and may they always be. http://www.geraldlhunsucker.com/
Gene Howe
#3 posted 04-08-2014 11:46 PM
Jeff, I have “Sawstop technology on the saw. It’s called a switch. Actually, there is a lower guard for the saw. It’s off for clarity. hee hee
Jerry, Sorry about damage to your project. Similar things have happened to me. I’ve had the stock fence slip during a dado cut. No more of that, now.
I have to get the table aligned with the jig, or visa versa, before I can initially register the fence against the blade.
Kinda of a fail safe.
View shipwright's profile
shipwright
7965 posts in 2762 days
#4 posted 04-08-2014 11:53 PM
That’s a nice looking rig Gene, but since I don’t have a used parts room like yours … :-) ... I’ll just keep using my good old standard fence and do my fine tuning with the quill. I’ve never really thought of a table saw as a precision tool anyway, probably because of the old behemoths I learned on in shipyards.
I should probably rethink that although I’m getting pretty set in my ways now.
View NormG's profile
NormG
5931 posts in 2968 days
#5 posted 04-08-2014 11:59 PM
Great solution
-- Norman - I never never make a mistake, I just change the design.
Gene Howe
#6 posted 04-09-2014 03:47 AM
Paul, I got totally frustrated trying to gain exactly 3/16 ths of an inch on a dado. Then when I finally got it dialed in, the damned fence slipped, ruining my lovingly prepared piece of curly maple.
Don’t you even mention precision to me. The things you do with the lowly Shopsmith and the Chevalet are super precise. BTW, Saw the new chart box. Awesome! Got the shading on the right piece, too. You guys have fun on the way back and, on your sailing journey.
View Jim Jakosh's profile
Jim Jakosh
20280 posts in 3069 days
#7 posted 04-09-2014 12:36 PM
Great fence, Gene!!!!!!!!!!!!!!!!...............Jim
View MrRon's profile
MrRon
4710 posts in 3207 days
#8 posted 04-09-2014 08:02 PM
To me, this is the greatest feature of these forums; the adaptability and inventiveness of it’s members.
View Tim Royal 's profile
Tim Royal
305 posts in 1450 days
#9 posted 06-12-2014 04:29 PM
“To me, this is the greatest feature of these forums; the adaptability and inventiveness of it s members.”
- MrRon
Truer words were never spoken!
-- -Tim Royal -"Pride makes us artificial and humility makes us real." -Thomas Merton
View stefang's profile
stefang
15881 posts in 3298 days
#10 posted 06-12-2014 05:36 PM
Great solution Gene. It’s always fun is seeing how individual woodworkers successfully solve their own perceived problems, whether or not the issues are considered problems by others. My own table saw is pretty inaccurate, but that pretty much fits my woodworking style and results. You seem to have much higher ambitions.
Gene Howe
#11 posted 06-12-2014 10:04 PM
thanks, Mike.
Not high ambition, just tired of a sloppy fence. And, I had the stuff to make it.
View azdustdevil's profile
azdustdevil
12 posts in 2809 days
#12 posted 03-26-2017 01:03 AM
Ah ha! I just purchased a “new old stock” Shopsmith and I just happen to have a couple of original gray plastic Incra Jigs that have been sitting around for years. Guess what I’m gonna do?
-- --so many tools....so little time
View r33tc0w's profile
r33tc0w
146 posts in 448 days
#13 posted 03-26-2017 04:21 AM
Gene, any chance you could take some more pics Of the jig by itself and maybe a shortened write up how to build this?
-- Matthew 13:53-58
