| Forum topic by Chill_Wills | posted 319 days ago | 1069 views | 1 time favorited | 9 replies | ![]() |
319 days ago |
Topic tags/keywords: sharpening stones hone Im looking to purchase my first sharpening stones and have only limited experience with an oil stone. I am tring to figure out which type of stone is best for sharpeng woodworking tools and is easy to use for someone with little sharpening experience. Price is also a consideration. Any advise would be appreciated. -- "Experience is often what you get when you were expecting something else" |
319 days ago |
I use water. I have some diamond stones too. Oilstones are messy but kind of nice to use. Waterstones I guess some guys figure the water makes the irons rust -- Would you like to recession-proof your present business using the internet? - my revealing 9-page free report gives you the straight facts: http://copymatch.com/rec/cap.html |
319 days ago |
I think scary sharp sand paper method is the best method for beginners. It is cheap, so you can get set up with a full range quick. After that waterstones are probably the best bet for good results. I have tried King and Norton brands. I prefer the Norton. You will need a good flattening surface as waterstones dish very fast. I use 220g sand paper on a granite surface plate. Water and tool steel don’t mix, so keep some oil around and coat the blades once done sharpening. I have moved onto oil stones. They don’t cut as fast, but they also dish very slow. I found that when prepping a new iron I had to flatten my waterstones several times during the process. No such issue with oilstones. I also don’t worry too much about sharpening my carving tools and chisels since the stones are hard enough not to groove. For a beginning sharpener the oilstones may not have fast enough results, but for me the benefits outweigh the negatives. Last and most importantly, get a leather strop. I put this off for months. I can say that had I gotten one earlier I would have spent much less time worrying over sharpening. With the strop you can go from a 4-6000g waterstone and have a beautiful mirror polished hone. The strop is also good for a few touch up honings between trips back to the stones. Basically a strop makes it easier to keep your blades razor sharp. -- Doug, woodworking in Alabama |
318 days ago |
If using the wet/dry paper method, or diamond, and are getting some flash rust, add a couple drops of dishwashing detergent to the water. It also works well on arkansas stones as it keeps the iron filings in solution so they do not load up the stone as fast. I do not have water stones, so do not know if this would be advisable on them. Go -- Go http://ncwoodworker.net/pp/showgallery.php?cat=500&ppuser=730 |
318 days ago |
What grit of stones or paper should I start with and finish with? -- "Experience is often what you get when you were expecting something else" |
317 days ago |
For the sandpaper method, I use: 1. A flat surface. A piece pf plate glass like a shelf from a medicine cabinet, will work, or you can use a cast iron table saw top, in which case you will want to use oil as a lubricant. If you can find a piece of flat polished granite, that is superb. 2. A honing guide. This will make life much easier starting out, as you can repeat the angle every time. This can be hand made from a block of wood, or commercially bought. The “Empire” style, which clamps the sides of the blade, can be had for about $15. It does poorly for chisels with beveled sides. The Veritas (Lee Valley) 05M02.01 ( about $36) has a clamp screw that sandwiches the blade, and just wide enough for the #5 or #7 Stanley irons (2 3/8”) but is also very good for chisels, especially those with beveled sides. The Veritas Mark II 05M09.01 (about $55) has a wider roller and will take a wider blade, but has a setting guide that makes it very easy to set the angles. The roller position is also adjustable, to allow very long angles such as a skew chisel or a low angle block plane iron. As the guides can be used with oil stones, water stones, or paper, it will be usable for about any hand sharpening technique. 3: Wet-dry sandpaper (available at most automotive repair shops, but especially those that cater to car painters like Carquest, etc). 220 grit – to set a new primary bevel angle, take out large chips in the edge, and flattening the back of a cheap iron or chisel that has deep machining marks. 320 grit – removing moderate chips, removing 220 grit scratches P400 grit – removing small nicks, starting point for a very dull blade, removing 320 grit scratches P600 grit – starting to get a serious edge. Starting point when touching up the edge on mine if they are moderately dull, removing 400 grit scratches. Also used to remove the wire edge on the flat back after using the above grits P1000 gr – Honing to sharp enough to shave with, removing 600 grit scratches, quick touch up as it dulls P2000 gr – final polish and light touch-up for squirrely grain Green rouge polishing compound – apply to leather strop, leather glued to flat board, or directly on unfinished flat piece of soft maple, etc. For use, blade is drug across from the back (not pushed edge first) to remove any 2000 gr scatches. (Wet Dry above 2000 grit is made but hard to find and expensive) Initially: Spritz water from an old spray bottle onto the glass and back of the paper. Lay paper on glass and go to work. (Some glue the paper with spray adhesive, but I find this collects grit and causes uneveen spots in teh paper, so I don’t do this) Start by flattening back of iron or chisel absolutely flat through the 2000 gr. Insert blade into honing guide and establish primary angle (for most Stanley blades 25 degrees is a place to start; bench chisels is about 35 degrees) and starting with 220, establish bevel all the way to the edge and through at least 2/3rds the blade thickness (all the way is better). Work through the grits to 600, and then flip blade over and remove wire edge with a couple side-to-side swipes. Establish the secondary bevel: Slightly increase the angle by a couple degrees (with the Veritas guides, you can just turn the knob on the roller to increase the angle 2 degrees, and with a home-made wood guide, slide a piece of cardboard under the back edge of the blade) and work thorugh the 1000 and 2000 grits. finish with a side-to side back swipe on the 2000. Rinse paper under a faucet to remove any iron and loose grit and store flat to dry Drag the blade backwards across the honing strop for the final polish. For touch-up, strop it. When that fails, go straight to secondary bevel and start at 1000 grit. It will only take a few swipes at each grit to get the edge back. When secondary bevel is more than 1/2 the blade thickness, start over with a new primary bevel. That’s how I do it. Hope this helps Go Ran out of time, so hope I didn’t forget anything. If I did, I’m sure others will fill in with their method. -- Go http://ncwoodworker.net/pp/showgallery.php?cat=500&ppuser=730 |
317 days ago |
I did forget one thing: Your best initial investment would be about $25 for Leonard Lee’s book “The Complete Guide to Sharpening”. It will give you all the info you need about the different ways to get to the same end – tools sharpened properly to do the job you want to do. Go -- Go http://ncwoodworker.net/pp/showgallery.php?cat=500&ppuser=730 |
317 days ago |
I was recently in a pretty deep conversation about oil stones and the consensus was that the coarse stones need a really thin oil to operate well. The oil that I had bought was too thick. WD40 or “lamp oil” work great to keep the stone cutting quickly. The fine stones, like a black, work well with the thicker oil. |
317 days ago |
I would say it depends on what you are sharpening and what condition they are in. For pocket and kitchen knives I prefer the diamond stones because they work fast and don’t require messy water or oil. I start with 400 or 600 grit and finish with 1200. I finish them off with a “crock” stick honing and if needed stropping on a green compound impregnated leather strip. Eze-lap makes a great product. www.eze-lap.com Their diamond is on solid steel without the holed and plastic base some others use. If you are working on chisels and planer blades I like the Work Sharp power sharpener which has disks from very coarse to the 2000 grit. It is essentially a revolving “sandpaper” method of sharpening. I have never really used water stones but I used oil stones for years and they do a great job. However, rather than using “oil” on them I used automatic transmission fluid because it is designed to suspend particles for the filter to catch, so guess what it does on the sharpening stone? Beats any oil i tried and a quart lasts for ever. Good luck with your new shop. -- Les B, Oregon |
317 days ago |
I started a few years ago with the sandpaper method method almost exactly as described by Gofor above. This was the easiest on my wallet, and I get such scary sharp blades, I never transitioned to stones as I had initially planned. I’d highly recommend it. Ive used the same method for truing plane soles. a bit more work, but great results. Ive also read articles on using dowels and various shaped pieces of MDF with this same sandpaper attached for custom curved sharpening “stones”, though I have not attempted this. One thing I’d add: I keep all of the silica (do-not-eat) packets from drug bottles, new purchases etc, and I just throw them into my tool box, tool bag, chisel case. Hope all this helps -- "If I find in myself a desire which no experience in this world can satisfy, the most logical explantion is that I was made for another world." -C.S. Lewis |
| Forum | Topics |
Woodworking Skill Share
2919 |
3945 |
256 |
950 |
224 |
Woodworking Trade & Swap
619 |
Coffee Lounge
2390 |
LumberJocks.com Site Feedback
524 |
