Motor wiring help
Forum topic by Shahidan posted 04-07-2014 01:39 PM 2122 views 0 times favorited 11 replies Add to Favorites Watch
View Shahidan's profile
Shahidan
28 posts in 1757 days
04-07-2014 01:39 PM
I wanted to use this electric motor (240v ac) to make a disc sander.
There are four wires coming out of the motor: white,red,yellow,blue and black, I hope somwone wil be able to tell me how to wire it up.
Thank you.
shahidan
11 replies so far
View WhyMe's profile
WhyMe
1080 posts in 1798 days
#1 posted 04-07-2014 02:49 PM
Hard to say without the motor brand or what it came off of. 2 wires are probably for a capacitor and a different combination of the 3 other wires for rotation direction. I know that doesn’t help.
View JollyGreen67's profile
JollyGreen67
1676 posts in 2999 days
#2 posted 04-07-2014 04:14 PM
What is the rotational speed ? It shouldn’t be more than 1750 for a disc sander.
-- When I was a kid I wanted to be older . . . . . this CRAP is not what I expected ! RIP 09/08/2018
View bigblockyeti's profile
bigblockyeti
5314 posts in 1957 days
#3 posted 04-07-2014 04:16 PM
Even if you have a make and model number that could go a long way toward someone being able to help you.
Shahidan
#4 posted 04-08-2014 03:34 AM
The motor was from an air conditioner blower unit.
Made in China.
Voltage 220vac Series: 4
Power 13W
Current : 0.21 amp
Capacitor: 1uF 450V
No speed indicated
Below is the circuit diagram.
Thanks to all.
Shahidan
#5 posted 04-09-2014 04:12 AM
I managed to get the motor working.
The unknown component was a thermistor but i removed it
The starting capacitor, 2 uF 400 vac, was connected across the white and red wires. The 230vac line was connected to the ends of the white and red wires.
The motor spin when power was switched on.I did not test the yellow and blue wires. As WhyMe said it could be for different speeds,
Now I could go ahead with what I had intended to do
Shahidan
bigblockyeti
#6 posted 04-09-2014 04:22 AM
I’ve played around with these a little, I suspect the black, blue and red are your different speeds, or more accurately different torques. Much like a ceiling fan motor or an air handler blower motor, they can spin at full speed with no load, the speed is reduced only when the load is applied. To check which speed (or torque) each of the wires represents, you could try all of them, the one that accelerates the rotor the slowest would be your slow speed and so on and so forth.
Shahidan
#7 posted 04-09-2014 01:53 PM
I could try that tomorrow. I hope the circuit breaker would not trip.
bigblockyeti
#8 posted 04-09-2014 02:00 PM
I doubt it would, these motors are generally designed to be very efficient, and don’t spin too fast so if it provides adequate torque it wouldn’t be too fast for a disc sander.
View Woodknack's profile
Woodknack
12464 posts in 2617 days
#9 posted 04-09-2014 03:51 PM
On my smaller hvac motors, red is low speed, blue is high; and they spin at slower speeds with our without load but of course yours may be different.
View dhazelton's profile
dhazelton
2805 posts in 2533 days
#10 posted 04-09-2014 03:55 PM
I think motors designed for furnace use are best repurposed as some type of air handler or air filtration unit. You might consider that by building a box and using a decent furnace filter to clean your air.
Shahidan
#11 posted 04-10-2014 05:05 AM
Thanks a lot,everybody for all you help and suggestions.
bigblockyeti : I was a bit apprehensive but the circuit breaker did not trip.
Rick M: In my case white gave the fastest speed. Bl ue medium speed and red needed a slight manual spin to run.It also gave the slowest speed.
dhazelton: I am an avid collector of all sorts of motors and I dreamed a lot about using them ! You gave me a good idea. In my small workshop I used an air conditioner compressor fan to cool the work area.
Thank you .
