Jointer or bandsaw
Forum topic by Peteyb posted 04-07-2014 01:54 AM 2602 views 0 times favorited 20 replies Add to Favorites Watch
View Peteyb's profile
Peteyb
131 posts in 2755 days
04-07-2014 01:54 AM
Topic tags/keywords: jointer band saw
I am looking into expanding my tools currently I have a 12” portable planer, 50” table saw, router table, drill press, and a dust collector. I am moving into a brand new shop that is 22’x22’. I am stuck one which tool I should get next. Should I get a jointer, 6” or 8”, or should I get a 14” band saw.
Currently I like to build cabinets and book cases for the house but have also started making some nice cutting boards too. So what do you think I should get first?
20 replies so far
View Loren's profile
10477 posts in 3847 days
#1 posted 04-07-2014 02:02 AM
For what you’re doing, a jointer.
A 6” machine really is adequate for a lot of work. If you’re getting
wider boards and buying rough stock though an 8” jointer
is useful, though a lot more money.
View lepelerin's profile
lepelerin
495 posts in 2524 days
#2 posted 04-07-2014 03:33 AM
What do you feel would be more useful for you. This is the answer.
If you are not sure between the BS and the Jointer, maybe you do not need them either :)
View Andre's profile
Andre
2210 posts in 2006 days
#3 posted 04-07-2014 03:51 AM
By looking at your projects, I’d say you could use a jointer, I picked up the Laguna 6” and could not be happier,
Them carbide heads will last me a life time!
View NiteWalker's profile
NiteWalker
2738 posts in 2776 days
#4 posted 04-07-2014 04:18 AM
By far, 8” jointer since you have the space. My shop is half the size of yours so I’d only fit a 6”. Get a spiral cutterhead parallelogram model if you can afford it.
Regarding a bandsaw, make that your next major tool purchase after the jointer. You can get by curve cuts for the time being with a jigsaw.
View waho6o9's profile (online now)
waho6o9
8516 posts in 2776 days
#5 posted 04-07-2014 04:25 AM
+1 for a jointer.
View pintodeluxe's profile
pintodeluxe
5798 posts in 3013 days
#6 posted 04-07-2014 06:27 AM
8” jointer. You would be surprised how many 6-1/2” boards you come across. My old 6” jointer was just a little too small for most boards. I upgraded to an 8”, and have been quite happy since.
Bandsaws are great, especially if you want to get into resawing. A jigsaw can suffice for cutting curves until you get a bandsaw.
View unbob's profile
unbob
810 posts in 2103 days
#7 posted 04-07-2014 07:54 AM
Just for safety using the table saw, a jointer is a good move. Gives one flat face and one straight edge.
Probably not talked about enough, a board that rocks on the saw table is dangerous.
View JaySybrandy's profile
JaySybrandy
78 posts in 1776 days
#8 posted 04-07-2014 08:08 AM
if u wont use them LOTS I would get a smaller bandsaw and a 6” jointer
Shawn Masterson
1325 posts in 2148 days
#9 posted 04-07-2014 01:05 PM
+1 for the jointer. A 6” is a good place to start. I would watch CL for an 8” and if you find a 6” for a steal, then you can use it till you can find bigger. If you get a steal on a 6” then you have wiggle room to sell it for a profit when you go bigger. I wouldn’t worry about spiral cutters for now, save the money. They are nice, but straight knives are fine for 95% of what you will do. I use a 6” for about 12 years, and just a month ago I finally found a steal on an
8”. Remember with CL it takes time and you have to have money in hand and be ready to pounce.
Happy hunting
View HorizontalMike's profile
HorizontalMike
7770 posts in 3113 days
#10 posted 04-07-2014 01:13 PM
+10 Jointer
The jointer complements the lunchbox planer, basically eliminating any remaining challenges for getting flat and square boards. The BS does NOT complement the TS nearly nearly as much nor in similar fashion as does the Jointer/Planer combination. Just my 2-cents…
View bondogaposis's profile
bondogaposis
5088 posts in 2551 days
#11 posted 04-07-2014 01:38 PM
Look at your next project, what would be more useful? Go with that.
-- Bondo Gaposis
View Mainiac Matt 's profile
Mainiac Matt
8553 posts in 2528 days
#12 posted 04-07-2014 02:07 PM
I have a similar sized shop with similar woodworking goals.
I use my jointer all the time and couldn’t get by without it.
I infrequently use my Bandsaw, and often could make do other ways.
-- I yam what I yam and that's all what I yam
View Gene Howe's profile
Gene Howe
11063 posts in 3628 days
#13 posted 04-07-2014 02:52 PM
+1 for the 6” jointer.
You have a planer and with a decent sled and some shims you can flatten any board up the the capacity of your planer. And once you get the hang of it, it’s more efficient than using a jointer.
View DrDirt's profile
DrDirt
4510 posts in 3942 days
#14 posted 04-07-2014 06:16 PM
I would get a bandsaw.
From your tools, it seems you have all stuff that cuts straight and flat.
You can do edge jointing at your router table, or using your planer, or even with a handplane.
You would add more to your capability with a tool that cuts curves, and also can resaw lumber. Perhaps you will get into bandsaw boxes.
I think the bandsaw would ADD the most to the shop.
If you go Jointer, get a used 8 inch or the Grizzly 8 inch.
I have a 6 inch delta, it works well is sharp, but I covet a larger surface… which I get using the planer and a sled.
Peteyb
#15 posted 04-08-2014 12:48 AM
Thanks for all the advice. I have been trying to watch craigslist for some time. I can not find one that I think I like. I think that I am going to purchase a Laguna Tools 8” Wedgebed Jointer with ShearTec II. What does everyone think about that.
