Delta 46-715 Bad Quill
« back to Woodturning forum
Forum topic by EdgewaterWW posted 04-06-2014 02:40 PM 1443 views 0 times favorited 12 replies Add to Favorites Watch
View EdgewaterWW's profile
EdgewaterWW
8 posts in 1583 days
04-06-2014 02:40 PM
Topic tags/keywords: delta quill lathe 46-715
I have a bad Quill in the tailstock, I need to remove it and order a new one.
It will come out to the 3” mark and move in to the 1” mark. It takes 2 people to get it to move this much.
I think it should keep on coming out to be removed?
Have any of you done this? How do you remove the quill?
Thanks
-- Doug - Edgewater, CO - http://www.facebook.com/EdgewaterWW - http://EdgewaterWW.Etsy.com
12 replies so far
View HorizontalMike's profile
HorizontalMike
7758 posts in 2939 days
#1 posted 04-06-2014 02:56 PM
I have had the morse taper stick once, but the quill should move the entire distance if there is nothing in the taper. Locking screws on the quill? The crank unscrews from the lead screw in order to remove the quill. Left hand threads? Don’t forget the set screw.
Got pictures?
EdgewaterWW
#2 posted 04-06-2014 03:16 PM
Thanks. Yeah I got all that done. No problem with any thing in the MT#2, locking screw, set screw.
I can remove every part off the tailstock but the Quill and the key.
Basically I’m asking does the quill come out the front or back when fully removing it? I need to know what way to hit it the a %#^ BIGGER HAMMER!
View TheDane's profile
TheDane
5441 posts in 3688 days
#3 posted 04-06-2014 03:29 PM
Just a WAG, but I would say it comes out the front (toward the headstock).
Check out http://www.ereplacementparts.com/delta-46715-type-castiron-lathe-parts-c-3275_9659_7667.html
View johnstoneb's profile
johnstoneb
2939 posts in 2198 days
#4 posted 04-06-2014 03:29 PM
Here’s a parts breakdown. Looks like it should come out the front. If it takes two people to move it sounds like it already got hit too much with a hammer.
http://www.ereplacementparts.com/delta-lathe-parts-c-3275_9659.html
-- Bruce, Boise, ID
EdgewaterWW
#5 posted 04-06-2014 03:58 PM
Thanks but I guess no one has done this.
I should say I know how to work a lathe and how a quill works. But like a car I can repair a lot of things, I can work the transmission but I have never removed it. YET.
I have looked over the parts Diagram and the worthless manual for hours, no real help, Yes the dotted line shows from the front.
“If it takes two people to move it sounds like it already got hit too much with a hammer.” You never know! I just got it used and abused from a High School.
HorizontalMike
#6 posted 04-06-2014 04:10 PM
Still, it just might be worth taking it to a contracted Delta Service Center, even if it cost you a few $$$. Mine was under warranty, but well worth the trip regardless. That is unless you are prepared to purchase an entirely new tail stock.
FWIW, and I had already beat it up with a hammer.
View Wildwood's profile
Wildwood
2322 posts in 2160 days
#7 posted 04-06-2014 07:41 PM
Don’t have that lathe, but when that happened to me on my old Delta. Took it apart from the rear starting with hand wheel, sprayed WD-40 with little twisting & turning everything came apart. Cleaned everything & put it back together. Not sure what caused things to jam up, once cleaned and put back together never happen again.
-- Bill
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3611 days
#8 posted 04-06-2014 08:01 PM
Sometimes the teeniest little tad of swarf or dust chippings wedged into the quill housing can cause the whole sheebang to sieze up.Taking it all apart and checking for roughness or dust and cleaning, if it is just dust or chipping.Then oiling and putting it all back together can very often work miracles. Alistair
View Nubsnstubs's profile
Nubsnstubs
1298 posts in 1755 days
#9 posted 04-07-2014 01:26 AM
There should be a groove on the bottom side of the quill. The groove might accomodates a roll pin, or some other protrusion located in the tailstock to keep the qiill from turning. If the groove is boogered, or the roll pin, the quill might have turned a little and is binding on said pin. Check the groove and see if it’s vertical with the center of the quill hole. If not, get it vertical, and remove the quill, and replace the pin….... Jerry (in Tucson)
EdgewaterWW
#10 posted 04-07-2014 05:28 AM
I got it out. With the tailstock in a vise, turning the wheel clockwise with both hands (taking a lot of work a real lot) for about 10 mins I got the Quill back to 3” out. Then disassembled the wheel, plate and Spindle Screw (just the tailstock and quill remaining) knocked out the Quill out the front with a wood dowel and a 2lb dead blow hammer.
Since no one was done this or was had a quill so damaged and stuck so hard in the tailstock, I will do a photo blog posting. Btw I repaired it and it’s working fine.
EdgewaterWW
#11 posted 04-07-2014 05:34 AM
P.S. Jerry good info, but that isn’t the description of a 46-715. The groove is at 9 o’clock not 6, no roll pin but a key (Delta term “Quill Scale”)
Nubsnstubs
#12 posted 04-07-2014 01:45 PM
Ok, so I was off a little, and I couldn’t come up with the clock positions. Getting old sucks. Hehe So, what was the problem???
I mentioned the roll pin because of my old Delta. It has a roll pin and groove that finally wore the edges of the groove, and the roll pin pushed down a little causing the quill to turn and locked up similar to your description. ........... Jerry (in Tucson)
