Shellac immediatley after Tung Oil
Forum topic by Luke2220 posted 04-06-2014 03:33 AM 1416 views 0 times favorited 9 replies Add to Favorites Watch
View Luke2220's profile
Luke2220
24 posts in 1779 days
04-06-2014 03:33 AM
Topic tags/keywords: tung oil shellac boiled linseed oil blo
I swear i found a video a week or so ago where someone used tung oil on a project, gave it a few minutes to absorb, wiped off the excess, and immediately applied shellac. I think I saw it on the Fine Woodworking website but can’t locate it.
Has anyone tried this?
Maybe I got it mixed up with Boiled Linseed Oil.
Thanks for the help!
9 replies so far
View TDSpade's profile
TDSpade
107 posts in 2651 days
#1 posted 04-06-2014 06:27 AM
Boiled Linseed oil, a light coat. I have tried this and it works well. I found the how to article in a Fine woodworking Quick and Easy projects magazine, fall 2012 printing. The article was by Jeff Jewitt.
-- For every expert, there is an equal and opposite expert.
TheWoodenOyster
1317 posts in 2170 days
#2 posted 04-06-2014 11:42 AM
I’ve seen that too. I think it was BLO in the article I read, but I agree with above. It said a light coat and then shellac right after. Weird to think there isn’t much curing time, but I guess with a light coat it doesn’t matter. Jeff Jewitt knows a lot more about finishing than most of us, so…
-- The Wood Is Your Oyster
5233 posts in 2728 days
#3 posted 04-06-2014 11:51 AM
View shampeon's profile
shampeon
1894 posts in 2418 days
#4 posted 04-06-2014 03:29 PM
Yes, I’ve done it. The alcohol in the shellac provides the oxygen for drying the oil, and the shellac provides a barrier coat that dries to the touch quickly.
You can also mix shellac with BLO/tung/Danish oil plus some DNA. A BLO/DNA/shellac mixture is my go-to wiping varnish.
View RockyTopScott's profile
RockyTopScott
1186 posts in 3713 days
#5 posted 04-06-2014 03:58 PM
Ian, what are the ratios in your go-to finish?
-- “When you want to help people, you tell them the truth. When you want to help yourself, you tell them what they want to hear.” ― Thomas Sowell
View lepelerin's profile
lepelerin
495 posts in 2560 days
#6 posted 04-06-2014 04:36 PM
I use tung oil and apply shellac right away. Works great.
shampeon
#7 posted 04-06-2014 04:53 PM
Equal parts, but I eyeball it. I mix it in a mason jar and shake it up before each application, since it’ll separate eventually. Works equally as well for finishing pieces on the lathe as a friction finish.
View Woodknack's profile
Woodknack
12455 posts in 2615 days
#8 posted 04-06-2014 05:12 PM
Pretty common in turning, you can even mix shellac and oil together and apply at the same time, just have to shake the bottle once in awhile.
Luke2220
#9 posted 04-07-2014 01:27 AM
Fred, thanks for the link. I knew it was at Fine Woodworking I just couldn’t located it. Spent a couple of hours looking and then thought to myself, “I betta ask somebody.”
