Spinning Saw Nuts
« back to Hand Tools forum
Forum topic by PeteHotard posted 04-04-2014 08:28 AM 955 views 0 times favorited 4 replies Add to Favorites Watch
View PeteHotard's profile
PeteHotard
3 posts in 1397 days
04-04-2014 08:28 AM
Picked up a Diston D-8 the other day for cheap. Went to take the handle off like I’ve done to a dozen other saws and two of the nuts are spinning in their respective holes rather than unscrewing from one another. If anyone has a solution to removing these two pesky nuts I would love to hear it. Thanks.
Pete
View DanielS's profile
DanielS
123 posts in 1807 days
#1 posted 04-04-2014 10:52 AM
I clamp a couple of thin boards across bothe sides. The board on the side with the slot should have a hole in it. The same idea is used here: http://alaskawoodworker.wordpress.com/2013/06/11/removing-a-spinning-saw-nut/. I dont have any clamps I want to drill holes in though. If it still spins, you can put a small piece of rubber on the dome side.
-- Daniel S
View Bluepine38's profile
Bluepine38
3377 posts in 2955 days
#2 posted 04-04-2014 05:02 PM
You could use a couple of scrap boards laid over the saw handle held by clamps on each end, easy to do
and you will not have to drill a hole in a clamp.
View chrisstef's profile
chrisstef
17100 posts in 2876 days
#3 posted 04-04-2014 05:06 PM
Had this happen to me just last night. I laid the face of the saw on a board and just clamped the handle to both the board and the bench. They unscrewed as they should from there. It was the first time ive had that happen to me. Coincidentally enough both saws were D8’s.
View enjuneer's profile
enjuneer
1 post in 1155 days
#4 posted 01-15-2018 04:43 AM
I use a Jorgensen clamp with a hole bored in one jaw to allow access with a screwdriver. The other jaw puts pressure on the saw screw. It has yet to fail me.
-- Bob Page
