Quick safety observation about the table saw splitter
Forum topic by jtm posted 04-04-2014 02:28 AM 1310 views 0 times favorited 7 replies Add to Favorites Watch
View jtm's profile
jtm
230 posts in 1659 days
04-04-2014 02:28 AM
I was just sawing a piece of rough walnut in half.
The wood closed back in on itself so hard that I had to take a mallet and hammer it back out.
Fortunately, I had my guard in place, and the wood closed in on the splitter. I honestly thought something else was wrong, because I could not believe just how hard it had closed in on itself.
I can’t imagine what would have happened if I had the guard off.
7 replies so far
16275 posts in 4241 days
#1 posted 04-04-2014 02:42 AM
I never cared for the one-piece guard/splitter on my Ridgid TS3660, so I started using a Micro Jig splitter instead.
Ripping with no guard or splitter at all is just asking for trouble.
View Paul's profile
Paul
721 posts in 1588 days
#2 posted 04-04-2014 02:49 AM
If it closed up and binded that hard that you had to use a mallet to dislodge it be thankful you weren’t using the plastic micro jig splitters.
How green was the wood you were working with? Almost sounds like a fence alignment problem to me.
Paul
Shawn Masterson
1325 posts in 1971 days
#3 posted 04-04-2014 02:58 AM
I’ve had some yellow pine pinch on a circular saw so hard that I had to wedge it open with a chisel to get my saw out.
runswithscissors
2764 posts in 2048 days
#4 posted 04-04-2014 06:03 AM
Only 3 or 4 days after getting my homemade riving knife installed in my Unisaw, I had a piece of oak do that. It stopped all forward motion of the board, though it didn’t grip as tightly as you’re describing. I was impressed and pleased to see that thing doing the job it was designed to do.
View Tony_S's profile
Tony_S
871 posts in 3106 days
#5 posted 04-04-2014 09:15 AM
If you weren’t cutting through a knot, or some other squirrely defect, the lumber is more than likely ‘case hardened’(lots of info on the net).
It’s a serious lumber defect caused by improper drying(too quickly).
Not only is it extremely unstable, but as you discovered, because of instability, can be quite dangerous.
First instinct is to try and put more pressure on the board and push harder to get through the cut. Even with a riving knife or splitter this is extremely dangerous, because as you manage to push it through(if you do at all), as you near the end of the cut(eg. last 6” of a 48” rip), there’s very little wood holding all that tension together and the board can actually split in half in front of the blade.
All that extra force you were applying is suddenly and unexpectedly released and your push block/hands move rapidly and uncontrollably towards the blade.
Outcomes vary from a load in your underwear…to a trip to the hospital for reconstructive surgery.
If in fact it is case hardened and the option is available, return it…it’s garbage.
-- It is the mark of an educated mind to be able to entertain a thought without accepting it. Aristotle
View robscastle's profile
robscastle
5078 posts in 2227 days
#6 posted 04-04-2014 09:34 AM
As long as you realise timber is a little unpredictable as it is cut,mainly you are relieving stresses and naturally a small amount of movement will be released.
Be it seasoned or milling green timber, the effect is still possible its a natural movement of the timber as you cut through it particularly noticeable on a saw mill.
That’s why the splitter is there!
-- Regards Rob
View hobby1's profile
hobby1
335 posts in 2320 days
#7 posted 04-05-2014 02:45 PM
There were times when I was cutting some lumber and the wood closed tight against the guard splitter, pushing the board further would keep tipping the saw on its feet, so when it gets that tight, I keep a wooden wedge shingle close by,
I cut the board until I get enough kerf past the guard splitter, to pound in the shingle wedge, enough to allow clearance,, then if need be, I’ll rip further down, until it binds again, shut the saw off, pound the wedge down further then finish the rip cut.
I did this for about a dozen rip cuts one day, it worked perfect, for fiishing a rip cut with that kind of stress in the boards.
