Dust Collection For Wood Shaping
Forum topic by Marc posted 04-03-2014 10:55 PM 1090 views 0 times favorited 10 replies Add to Favorites Watch
View Marc's profile
Marc
101 posts in 3035 days
04-03-2014 10:55 PM
Topic tags/keywords: dust collection shaping sculpting
Hey Everyone.
I’m going to be doing a few projects where I am planning on doing a lot of wood shaping/sculpting (like Andy’s, and other’s, sculpted art boxes). A lot of this will be done with an angle grinder and I’m wondering about dust collection. I’m thinking one of those dust shrouds that can attach to the angle grinder will get in my way as I move around the piece but it is the cheapest option so I may just have to try it out. I’ve currently just got a shop-vac but the wife is starting to complain more about the dust so a (reasonable) upgrade has been approved. I just don’t see a real good option for the angle grinder type of work where me and the tool are moving around the work piece. I’m thinking a ceiling mounted air cleaner may be a decent option. What are your thoughts? I should also mention this is just a garage based workshop so floor space and electrical options are limited.
Thanks in advance.
-- Marc, http://www.logicallymarc.com/
10 replies so far
View SWCPres's profile
SWCPres
29 posts in 1555 days
#1 posted 04-04-2014 12:28 AM
This is purely an idea that came to my head when I read your post, never tried this myself. It looks like your getting a real DC from what I gather. The more CFM the better. I am sure you can find ample information on the subject of which one to get. Now on to the idea. Large homemade scoop (plywood, plexi, whatever.) Box fan on the other side of the scoop to push the dust into it. DC hooked up to the scoop. No real details, just thinking in terms of how I have set up spray booths. As far as the ceiling mounted option goes, it’s really more fine suspended particulates that your standard DC missed, not really a substitute for such. If you just get a ceiling, you’re gonna continue to see dust all over everything. Best method of DC is as close to the source as safely possible and as much CFM and you can stand/buy.
-- Reinventing the "Wheel", one 800mg Ibuprofen at a time.....
View Marc's profile
Marc
#2 posted 04-04-2014 03:58 AM
I was actually hoping to avoid a true dust collector, just due to floor space and electrical concerns. I hear what you’re saying though. I was thinking about a scoop or hood too but figured I would have to stay pretty close to it to really capture much dust. Maybe I’ll just strap the hose of my shop vac to the angle grinder. That’s as close to the source as I could get. (Just kidding, kind of.) ;-)
View Loren's profile
10476 posts in 3674 days
#3 posted 04-04-2014 04:09 AM
You can spritz the air with water regularly on breaks from
running the grinder. This will encourage the fine dust to
move to the ground.
A dust collector really is the better solution. You could
also build a downdraft system and perhaps a shop vacuum
would be adequate to get started with.
View Marc's profile
Marc
#4 posted 04-04-2014 04:25 AM
Yes, a downdraft table had crossed my mind at one point but I forgot about it. Thanks for the reminder.
View Paul's profile
Paul
721 posts in 1591 days
#5 posted 04-04-2014 04:26 AM
A shop vac with an air hood simply doesn’t pull enough cfm to justify not getting and using a dust collector. HF has their 2hp dc on sale ATM. For the price and your lungs it’s pretty inexpensive. I have a jet air purifier that I run 100% time along with my dc and it’s made a huge difference.
No more sticking my little finger down my nose at the end of the day to get dust boogers out.
A true dust collector and separator are night and day a better option. A bit more expensive but it’s really well worth it.
Paul
runswithscissors
2767 posts in 2051 days
#6 posted 04-04-2014 05:53 AM
Just a thought: put the carving on a turntable. I know it’s a long shot, but an old barber’s chair would make a superb turntable for a carver—you could spin it around, lock it in place, and make it go up and down.
This way setting up your dust collection would be simplified.
View JaySybrandy's profile
JaySybrandy
78 posts in 1602 days
#7 posted 04-04-2014 06:11 AM
I would just let it drop on the ground then sweep or suck it up
View Marc's profile
Marc
#8 posted 04-05-2014 01:32 AM
Thanks for all of the suggestions. I’m thinking a downdraft table and possibly a hood hooked up to a DC would probably work best for me. I’ll think about it some more and see what I can squeeze into the budget (and the garage). ;-)
View widdle's profile
widdle
2069 posts in 3025 days
#9 posted 04-05-2014 02:30 AM
I have tried a few different set ups..including medium side hoods. but now just use a 4” pipe mounted to a block, that i clamp to the bench.
View TheDane's profile
TheDane
5441 posts in 3689 days
#10 posted 04-05-2014 02:40 AM
Depending on the size of the workpiece, you might be able to use a lazy-susan platform so you hood/dust collection/whatever could be fixed with you working on the opposite side.
You could easily make one with a couple of pieces of plywood and a $10 lazy-susan hardware kit from a home center.
I have a lazy-susan that I use for spray finishing small items … works like a charm.
