New wood
Forum topic by russty posted 01-11-2009 02:45 AM 668 views 0 times favorited 3 replies Add to Favorites Watch
View russty's profile
russty
45 posts in 3310 days
01-11-2009 02:45 AM
Ok what is it I acquired some wood from my sisters garage. they are 4×4 ft sheets about 1/4 thick and very flexible. not corrigaeted or waffle, very smooth but could roll into a tight circle.
what is it
what would u use it for
how strong is it
and how durable is it
-- With God's help all things are possible- even woodworking
3 replies so far
35097 posts in 4273 days
#1 posted 01-11-2009 02:47 AM
Bendy ply I assume they bend one direction and not the other. It’s bendable plywood used to make pillars or other shapes like that.
I believe that they are very strong. They would usually be covered with veneers of formica type products.
russty
#2 posted 01-11-2009 03:29 AM
Thanks
had to go out to the shop to see
it seams that they bend both ways
Could you use them as they are
Russ
#3 posted 01-11-2009 03:43 AM
OK let me ask a different way. I assume that they bend with the grain but not across grain. Meaning you can’t bend them at 90 degrees from the first bend. I guess they coould be used as regulat plywood but they don’t have any real strengh unless they are formed into a curve.
They probably are expensive. At least more so than regular plywood.
