Air Drying Lumber
Forum topic by gfadvm posted 04-03-2014 01:58 AM 1623 views 0 times favorited 25 replies Add to Favorites Watch
View gfadvm's profile
gfadvm
14940 posts in 2714 days
04-03-2014 01:58 AM
Topic tags/keywords: air drying lumber
I recently posted a question on the Forestry Forum that may be of interest to LJs:
How dry can I expect properly stacked and stickered sawmilled lumber to get in NE Oklahoma? (indoors in an unheated,well ventilated building) The answers I got indicated that 15% is all I can expect.
I would have been waiting forever for it to get to 8-10%!
25 replies so far
View Monte Pittman's profile
Monte Pittman
29390 posts in 2362 days
#1 posted 04-03-2014 02:02 AM
In theory, it shouldn’t go below your normal humidity level. Mine can get to 8%-10%.
View pintodeluxe's profile
pintodeluxe
5704 posts in 2838 days
#2 posted 04-03-2014 02:04 AM
Yes, it takes a kiln or a very dry climate to get lumber below 10% m.c.
However lumber that is air dried to 15%, and then kiln dried is very stable. It is not as prone to warping and checking as green lumber that goes straight in the kiln.
Monte Pittman
#3 posted 04-03-2014 02:07 AM
We could turn that back room in your storage building into a kiln!
18351 posts in 1881 days
#4 posted 04-03-2014 02:24 AM
This calculator tells you what the theoretical equilibrium moisture content would be at a given temperature and RH. Trying it out a few times it looks like it gives lower values than you have been told, but this calculator assumes constant conditions. Obviously in reality the conditions will change constantly and the average over the accepted one year of drying for one inch of wood will be quite low.
http://www.csgnetwork.com/emctablecalc.html
gfadvm
#5 posted 04-03-2014 02:25 AM
According to the FF guys our average daily humidity here is 60%. Odd that wood will dry to 15% but I’m glad!
Monte, Nah, that’s where the new planer is going!
#6 posted 04-03-2014 02:34 AM
Wood moisture content is a comparison of the woods actual weight to its oven dry weight, whereas RH is a measure of the amount of water in air at a given temperature compared to what it could hold at that temperature. Similar methods, but the numbers don’t compare.
View Blackie_'s profile
Blackie_
4883 posts in 2537 days
#7 posted 04-03-2014 04:03 AM
Andy 15% is all I’ve seen down here in TX as well, that’s even on trees that have been dead for years, it’s been worked fine for me so far.
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at http://www.facebook.com/randy.blackstock.custom.wood.designs
View Wildwood's profile
Wildwood
2322 posts in 2159 days
#8 posted 04-03-2014 10:35 AM
Drying wood is a water removal process we all know moisture leaves wood through evaporation. Have you thought about using fan or fans to increase air circulation to help bring down MC?
Would think if brought some boards into your shop and let it hang out for a few months before use will also bring down MC.
-- Bill
View WDHLT15's profile
WDHLT15
1747 posts in 2500 days
#9 posted 04-03-2014 11:43 AM
I have air dried tens of thousands of BF of hardwood. Once it gets air dry, and if I bring it into my unheated and uncooled (no climate control) shop, it will lose a % or two from the air dried moisture content. If the shop was climate controlled, the change would more likely be in the 5 – 6% moisture drop from the air dried state.
Humidity limits how dry wood can get because at some point with the given amount of water in the air with a given humidity, the air cannot hold more moisture at that given temperature, and there will be no additional evaporation of water from the wood. Lower the humidity from that point, and the air can hold more water, so evaporation of water from the wood will resume. Increase the humidity, which means more water vapor in the air, and the wood will increase in moisture content as it picks up moisture from the air.
Because the ambient humidity changes over the course of the seasons, wood will gain and lose some moisture as the humidity changes. This results in wood movement as the wood will shrink or swell a bit as it moves to equilibrium with the humidity. Being a good woodworker means understanding, planning for, and managing this seasonal wood movement.
View Broglea's profile
Broglea
685 posts in 3115 days
#10 posted 04-03-2014 12:16 PM
Good topic.
Why worry about reaching 8% MC? If I build a dresser with wood that is 8%, won’t after a number of years of sitting in a house (Non climate controlled) the wood in the dresser increase MC to 12%-15%?
Why not just air dry it to 15% to begin with?
gfadvm
#11 posted 04-03-2014 01:36 PM
Wildwood, I neglected to mention that I have a fan running in this building 24/7 with open gable vents.
Danny, Thanks for weighing in. Your input is always appreciated as I’m pretty new at this sawmill thing! But I am having way too much fun!
View Bluepine38's profile
Bluepine38
3379 posts in 3110 days
#12 posted 04-03-2014 03:20 PM
I looked at the weather for Jenks, OK and it indicates average temps of 93 degrees in July and August. If
you used a solar kiln or just a building with an exhaust fan, I am sure the moisture content would get way
down for two months, of course it would just go back up the rest of the year. Sorry, just could not resist
because I know how dry the wood gets in my shop in heat of the summer.
gfadvm
#13 posted 04-03-2014 07:34 PM
Bluepine, I’m interested to see what it does this summer as it does get hot but the humidity is often 80% during that time. We’ll see…....
View AandCstyle's profile (online now)
AandCstyle
3071 posts in 2281 days
#14 posted 04-03-2014 11:27 PM
Andy, I am in the NM high desert. I will be happy to store all the wood you care to send me! ;)
-- Art
gfadvm
#15 posted 04-04-2014 02:16 AM
Art, Come to Tulsa and I’ll load you up with some native Oklahoma lumber. The blackjack is spectacular and I have never seen any for sale.
