dado problem
Forum topic by sawdust99 posted 03-31-2014 07:34 PM 845 views 0 times favorited 9 replies Add to Favorites Watch
View sawdust99's profile
sawdust99
26 posts in 2763 days
03-31-2014 07:34 PM
I’m trying to cut 1/8 inch deep dadoes around the center of a keepsake box on top and 4 sides. I have done everything on my table saw and can’t get the dadoes to match. I made sure everything was in line on setup with a caliiper. for some reason one or more of the dadoes offsets the matching. Is there a better way to do these dadoes. The box is 6” wide, 9” long and 3” high. Thanks for any help.
9 replies so far
View BinghamtonEd's profile
BinghamtonEd
2286 posts in 2241 days
#1 posted 03-31-2014 07:54 PM
Did you have a constant reference for all the dados? In other words, did you reference the bottom edge against the fence for all, or the top edge, etc? Are all your pieces accurately cut ot the same size? I don’t know how you’d have offset dados unless your reference point changed, or the fence moved. We’re you using a miter gauge, and did you verify it is properly set at 90deg to the blade?
sawdust99
#2 posted 03-31-2014 08:13 PM
I did all that and can’t find any place that would cause the problem . Been working on problem for 2 days. It may just be something simple and I’m missing it. That is why I asked for help.
BinghamtonEd
#3 posted 03-31-2014 08:19 PM
Understood, I thought you were looking for input on what could have gone wrong. Until we figure that out, we don’t know how to improve on it. If the fence stayed put, and the miter slot is parallel to the blade, and miter gauge (if used) is square to the slot, I think the only other cause would be how the stock was actually fed through the saw. How far offset are they? And is the dado parallel to the reference edge?
View gfadvm's profile
gfadvm
14940 posts in 2562 days
#4 posted 04-01-2014 12:44 AM
I would check to see if you have some ‘toe out’ on your tablesaw fence (back edge being a skosh further from the blade). Good for preventing kickback, but a problem when sawing around a box.
View kdc68's profile
kdc68
2636 posts in 2148 days
#5 posted 04-01-2014 12:44 AM
+1gfadvm
-- Measure "at least" twice and cut once
View MrRon's profile
MrRon
4564 posts in 3115 days
#6 posted 04-01-2014 04:53 PM
Can you use a router instead?
View HorizontalMike's profile
HorizontalMike
7727 posts in 2785 days
#7 posted 04-01-2014 05:04 PM
Possible suggestion: Before cutting each of the four sides, why not cut the dado while the wood it still as one and then cut to length?
16272 posts in 4090 days
#8 posted 04-01-2014 06:20 PM
Mike’s got the right idea.
My first thought was toe-out on the fence, as gfadvm mentioned. But if everything with the saw set up is 100% correct, the problem has to be with the box. If the opposing sides are not all perfectly perpendicular, and all the angles are not exactly 90 degrees, you’ll get the result you’re getting.
sawdust99
#9 posted 04-01-2014 08:21 PM
After checking the saw for any possible causes of my problem , I no longer think it is the saw. I’m going to make another box and check each piece as I go to see what may cause my problem. I thank everyone for your input.
