0.025" 1095 spring steel ( saw steel )
Forum topic by RonB57 posted 03-31-2014 05:11 AM 1914 views 2 times favorited 2 replies Add to Favorites Watch
View RonB57's profile
RonB57
25 posts in 2345 days
03-31-2014 05:11 AM
Ok. Long story short, I wound up with an extra 50 lb coil of 1095 spring steel. 0.025” thick. Same stuff I use in my saws. So here’s the deal. Saw Plates – de blued, teeth punched, up to 6” wide x 18” long. For just $15.00 each plus shipping. You can buy one plate, 10, or 20. Either way, I need to get it out of the way. Just mention Lumber Jocks offer when you contact me. Thanks in advance. Ron
-- BontzSawWorks.net
2 replies so far
View realcowtown_eric's profile
realcowtown_eric
608 posts in 1934 days
#1 posted 03-31-2014 05:36 AM
Can you PM me some pix????
Eric
-- Real_cowtown_eric
RonB57
#2 posted 03-31-2014 01:48 PM
Hi Eric. Not really anything to take a pic of. It is a 12”wide roll of 0.025” 1095 spring steel. It’s blue. :) I will cut it to length, ( rectangles ) and width, clean the bluing off, punch the teeth, and flatten it. Then it will look like any other saw plate.
Just for fyi. It would be a lot less expensive, per plate, in regards to shipping if you bought more than one plate.
As far a ppi. This is 0.025”. Think 3” tall to 5.5” tall for carcass to large tenon saw.But I can punch it from about 5ppi to 17ppi. That’s up to you.
