New Saw
Forum topic by z29 posted 03-30-2014 10:50 PM 1638 views 0 times favorited 9 replies Add to Favorites Watch
View z29's profile
z29
7 posts in 1514 days
03-30-2014 10:50 PM
Bought the TS3660 for $300 off GL, after searching the reviews on comparable saws it seemed like this one rated pretty well. So, I could use some advice on accessories and any mods to it, as this is my first saw of this size and ability to do work on a new level. Thanks in advance.
-- Stan
9 replies so far
View hoosier0311's profile
hoosier0311
706 posts in 1994 days
#1 posted 03-31-2014 12:16 AM
I have had that saw now for a tad more than 5 years. I had to put bearings and an arbor shaft in it, (cost 40 bucks) I have no problems with the fence. The miter gauge is a little weak. Id upgrade that. Make some zero tolerance inserts and I think you will be good to go. rigid says it’s 1.5 HP, not sure how accurate that is, but good blades are a must.
-- atta boy Clarence!
View Minorhero's profile
Minorhero
373 posts in 2573 days
#2 posted 03-31-2014 12:38 AM
My first saw was the 3650 which is essentially identical to your saw. It was a good saw and I only got rid of it because I found a used unisaw for cheap.
You should buy a featherboard for safer cuts. I use a Grip-tite magnetic featherboard for almost every cut and I highly recommend it.
http://www.amazon.com/Mesa-Vista-Design-GRIP-TITE-Featherboard/dp/B0000223VF/ref=sr_1_2?ie=UTF8&qid=1396226091&sr=8-2&keywords=griptite+magnetic
I would definitely make sure you have a good saw blade. If you go with a thin kerf blade make sure you buy some blade stiffeners to go with it. Otherwise buy a full kerf blade. I would recommend saw blades from Forrest or Tenryu Gold Series. These will be relatively expensive. Expect to pay 100+ per saw blade. But if you get lousy cuts, what was the point?
The mobile base on this saw is still my favorite of any tool I have ever owned.
View toolie's profile
toolie
2120 posts in 2597 days
#3 posted 03-31-2014 01:47 AM
in this order:
blade (re-thought after scott’s post)
ZCI
incra v27 miter gauge
outfeed table
crosscut sled
convert to 220v is your shop has limited power like mine
that’s a great TS. with care, it could very well be a forever saw. WOOD magazine uses a 3650 for many of their shop projects. a cabinet saw isn’t mandatory for fine woodworking.
also, if you don’t mind losing the functionality of the tape on the front rail, the front and rear rails can be slid to the right for 6 to 12” more rip capacity to the right of the blade.
NOTE: where’s the spreader rod that goes between the front and rear rails to the right of the right side extension table? that rod, and the provided shims, prevents the front and rear rails from pinching together when the fence is clamped down to the right of the CI table and it’s extensions. it’s a pretty important part of the fence system.
View knotscott's profile
knotscott
7983 posts in 3344 days
#4 posted 03-31-2014 01:49 AM
That’s a well proven contractor saw…you did well. Get it aligned, and buy a good blade or two for it. You shouldn’t need blade stiffeners unless there’s a problem.
Current saw blade bargains
View Greg In Maryland's profile
Greg In Maryland
553 posts in 2966 days
#5 posted 03-31-2014 02:11 AM
As others said, you did well.
I have the 3650 and built an outfeed table similar to the one described here: Rigid Forum. Ok, identical to this one. The only thing I might have done different would be to construct a folding out feed table. It takes up a fair amount of real estate in my basement that I could otherwise use.
I also got rid of the stock dust “collection” and replaced it with a home made chute and dust port. I also needed to cover up the back end of the saw to improve dust collection. I used 1/4ths MDF and small magnets for that. Rockler, Woodcraft, Grizzly, etc. all sell adapters that could easily be modified for use on your saw.
Dust collection under the table is pretty good. On the top of the table, it is pretty much non-existent. I am thinking of making an articulated/cantilevered arm-type arrangement to take care of that issue. Something on the lines of this from Wood Magazine
I also replaced the stock miter gauge with the Incra V27 miter gauge and made a cross cut (panel) sled. Both work like a charm and make life that much easier.
I have been very pleased with my 3650 and from the looks of it, you scored a nice saw.
Have fun!
Greg
View NiteWalker's profile
NiteWalker
2736 posts in 2545 days
#6 posted 03-31-2014 03:45 AM
Here’s what I wold do:
- Align it. Goes without saying.
- Outfeed table. There’s a lot of nice designs for that saw. Search “TS3650 folding outfeed table”.
- Right side extension table. It would eliminate the need for the bar between the front and rear rails. Keep it simple; a simple piece of 1/2” or 3/4” plywood or MDF with formica on it on a frame of hardwood with a few cross braces to keep it flat.
- ZCI’s. Here's a great article on making them. I’m using 1/4” baltic birch plywood for the inner layers instead of hardboard.
- Crosscut sled. Definitely a must.
View z29's profile
z29
#7 posted 04-01-2014 09:53 PM
Thanks for all the suggestions, I now have a lot to ponder. Am thinking dust collection as well.
-- Stan
View cutworm's profile
cutworm
1075 posts in 2762 days
#8 posted 04-01-2014 11:56 PM
Sweet! I bought mine about 4 years ago and really like it. I can’t imagine needing something better.
-- Steve - "Never Give Up"
toolie
#9 posted 04-03-2014 01:12 AM
just curious. bob d’s model for a 3650 outfeed table is a folding table. or am i missing something?
