Lie Nielsen 62 Low Angle Jack Plane Blades
« back to Hand Tools forum
Forum topic by TechTeacher04 posted 03-30-2014 12:02 AM 1512 views 0 times favorited 3 replies Add to Favorites Watch
View TechTeacher04's profile (online now)
TechTeacher04
362 posts in 1402 days
03-30-2014 12:02 AM
Topic tags/keywords: plane question
I currently own the Lie Nielsen 62 plane. I have 2 blades ones sharpened at a low and the other at a high angle. Has anyone tried using their scraper blade? I have considered buying a scraper plane, but if the scraper blade in the 62 is effective I can save up for another tool instead.
3 replies so far
View Loren's profile
9760 posts in 3518 days
#1 posted 03-30-2014 12:07 AM
If you don’t have a Stanley no. 80 type cabinet scraper
I recommend you acquire one. It has a short sole and
handles on the sides that allow a lot localized pressure.
Because the sole is short you can see what you’re doing
pretty well.
I have one of those L-N low angle jacks. Never used
a scraper blade in it, and never thought I needed
one.
TechTeacher04
#2 posted 03-30-2014 12:10 AM
I own 2, one has a Hock blade in it, i am just concerned about keeping everything flat.
#3 posted 03-30-2014 03:10 AM
The no. 80 cannot force a user to make a hollow. The user
does that. A jack plane is really too long for smoothing.
A smooth plane bedded at 55 degrees or with a 10 degree
back bevel on a standard smooth plane will plane/scrape
most American hardwoods to a reasonably consistent
surface. You might consider the double bevel sharpening
method championed by Brian Burns.
Lots of people try to work through this issue with a drum
sander. I do not recommend it especially since it is a tedious
approach. Stroke sanders are a lot faster.
