Zero Clearance Insert
Forum topic by bbc557ci posted 03-29-2014 10:02 PM 914 views 0 times favorited 7 replies Add to Favorites Watch
View bbc557ci's profile
bbc557ci
595 posts in 1946 days
03-29-2014 10:02 PM
Hi all….Anyone here ever try using one of those plastic (I think) cutting boards from Wall/K-Mart for a zero clearance insert? I’d like to make one or two for my Unisaw and was wondering if that material had been tried before.
Any other ideas on materials to use is also certainly welcome!!
Thanks in advance :o)
-- Bill, central NY...no where near the "big apple"
7 replies so far
116804 posts in 3449 days
#1 posted 03-29-2014 10:08 PM
MDF is cheep and works great.
bbc557ci
#2 posted 03-29-2014 10:13 PM
a1Jim – yer gonna laugh, but I’ve never used MDF, for anything. I know nothing about it but I know allot of LJs put to use for allot of things. Does it come in 1/2 inch?
#3 posted 03-29-2014 10:26 PM
bbc557ci
#4 posted 03-29-2014 10:28 PM
Thanks Jim. I’m already on the HD site and found it in 1/2 in.
View woodchuckerNJ's profile
woodchuckerNJ
1251 posts in 1506 days
#5 posted 03-29-2014 10:33 PM
Jim, MDF used to be cheap.
Don’t know what it costs by you, but it has gone up dramatically here in NJ in the last few years.
Anyway, like Jim says mdf is a good material, I put formica on both sides then rabbet the bottom edges so it is lower than the top. Then I put screws in, or you can try the hot glue method.
I did buy a cutting board at HF for the purpose, but have never used it as I had so many blanks I made, I have not used up my MDF, formica blanks yet.
Try it and let me know how you like the cutting board.. :-)
-- Jeff NJ
View joek30296's profile
joek30296
53 posts in 2738 days
#6 posted 03-29-2014 10:58 PM
I’ve made a number of ZCI’s out of MDF and they worked well. However, I recently made one out of a piece of Corian I had laying around the shop. Drilled it and tapped for leveling screws and it works great.
-- "There are two theories to arguing with a woman....neither of them work"
View Harryn's profile
Harryn
58 posts in 2460 days
#7 posted 03-29-2014 11:41 PM
I have made many inserts using laminate flooring. Works great. Stiffer and harder than MDF.
