Breaking the Corners of Mitered Boxes
Forum topic by Dchip posted 03-29-2014 04:07 PM 889 views 0 times favorited 2 replies Add to Favorites Watch
View Dchip's profile
Dchip
271 posts in 3245 days
03-29-2014 04:07 PM
Topic tags/keywords: question trick box boxes
Getting a tight miter on a box can be tricky. But when you do, you’re left with four very sharp corners. Do you guys break these at all? I’ve found that even light breaking with 1500 grit sandpaper exposes some end-grain that then darkens with finish. It’s very slight but still takes away from the “perfect” miter.
-- Dan Chiappetta, NYC, http://www.9x7woodworks.com
2 replies so far
View shipwright's profile
shipwright
7979 posts in 2791 days
#1 posted 03-29-2014 06:07 PM
I do marquetry boxes with 1/42” veneer and try to avoid using “corner strips” often because I want to see the continuation of the grain or pattern through the corner. I do just ease the corners a tiny bit but I’ve just looked at a few and don’t see any color irregularities. Here’s an example.
Maybe you are just being too hard on yourself. Looking at your projects, I’d say you have the skills.
View Jim Finn's profile
Jim Finn
2656 posts in 2915 days
#2 posted 03-29-2014 09:06 PM
I sand the corners a bit on the small boxes I make with mitered corners, of cedar and of oak. No problems. I use no stain, white glue and shellac finish.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
