Smoothing/deburring planer bed?
Forum topic by ADHDan posted 03-28-2014 02:15 PM 1319 views 0 times favorited 17 replies Add to Favorites Watch
View ADHDan's profile
ADHDan
800 posts in 2075 days
03-28-2014 02:15 PM
Topic tags/keywords: question
I have a DeWalt 734 planer, and I love it. For a relatively cheap lunchbox it’s kind of a beast, and since I don’t have a jointer it also does face-jointing with a sled. And that’s where I screwed up. I was flattening some cherry by countersinking screws through a piece of plywood; where the cherry was warped high, there was a gap between the sled and the board (bridged by the screw). Unfortunately, the screw threads didn’t bite into the plywood as well as I expected, and the rollers pushed the screws out – leaving a few gouge streaks in my planer bed and feed tables.
I don’t really care about the cosmetic damage, but the gouges effectively are like lines of burrs running all the way through the beds. So now when I use the planer, they dig into the underside of the board and leave streaks that look similar to what you get when you plane a board using chipped knives.
Any advice on how best to deburr/smooth out the beds? Thanks!
-- Dan in Minneapolis, woodworking since 11/11.
17 replies so far
View johnstoneb's profile
johnstoneb
2869 posts in 2139 days
#1 posted 03-28-2014 02:31 PM
You might try a stone. If that doesn’t take them down you’ll probably be ahead replacing the table.
-- Bruce, Boise, ID
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3679 days
#2 posted 03-28-2014 02:35 PM
Maybe a bit of filing or sand paper would even the burrs out. The metal of these decks is not super hard so should sand pretty well. You may have to pay special attention for rusting in the sanded area but if you are waxing you tables anyway that shouldn’t be a problem.
17954 posts in 1823 days
#3 posted 03-28-2014 02:36 PM
How about a random orbit sander with like 320 grit. Then a coat of wax.
View BinghamtonEd's profile
BinghamtonEd
2297 posts in 2336 days
#4 posted 03-28-2014 02:49 PM
I’d probably take a 10-12” square granite-type tile (I have a couple I got for $2-3 at HD for attaching sandpaper to for sharpening) and apply a sheet of fine (maybe 400-grit, depending on the bur size) to it, then just rub it back and forth on the bed to remove the burrs, letting the weight of the tile do the work. Since it’s a 12.5” planer, it’ll make sure you sand the entire bed evenly.
ADHDan
#5 posted 03-28-2014 02:53 PM
Thanks all. It looks like I’ve got a lot of options short of the drastic step of replacing everything. I already made some progress hand sanding with 200 to 400 grit paper; I’ll try taking an ROS to it and then smoothen with a diamond file or stone. Once I’ve got the burrs out, I’ll do a test run to make sure wood still runs through flat and square. If it doesn’t, I’ll try the 12” tile idea.
And I suppose this is just the kick in the pants I need to make sure I wax my beds regularly.
View Mark E.'s profile
Mark E.
387 posts in 3709 days
#6 posted 03-28-2014 03:01 PM
If the above suggestions don’t work, you could add an auxiliary bed to cover the original.
-- Mark
BinghamtonEd
#7 posted 03-28-2014 03:07 PM
You could post it on Craigslist for $400.
#8 posted 03-28-2014 03:11 PM
He could and then we’ll see it on the ‘Craigslist posters have gone crazy” thread.
ADHDan
#9 posted 03-28-2014 03:39 PM
Considering I got it for $250 “used” (i.e. purchased and hoarded in an unopened box for five years), I think I’m going to try some home remedies before asking $400 on Craigslist.
If I can’t get the scratches out I may give serious thought to an auxiliary bed, and maybe even extend my in and outfeed tables. But hopefully I can at least smooth the burrs.
View Allen4's profile
Allen4
9 posts in 1489 days
#10 posted 03-28-2014 04:29 PM
I am trying to resurface an aluminum bed covered in stainless steel sheet .3mm thick. The corner has lifted and junk has gotten under, so I am going to resurface it with either stainless or mild steel sheet contact cemented on. I would think about grinding the high parts flush with light sand paper and resurfacing to cover the low gouges. If you sand them out you won’t have a flat table anymore. doesn’t have to be thick I think I’m going with 22 gauge mild steel
View unbob's profile
unbob
808 posts in 1870 days
#11 posted 03-28-2014 04:43 PM
The first response is the correct one. Dress the burrs with a stone. Narrow gouges left from screw points will have no effect on the machine performance, once the burrs are removed.
Always, resist using wood working tools to repair machines, or other metal objects that have been machined, such as sanding, ect.
ADHDan
#12 posted 03-28-2014 05:15 PM
Can you recommend a stone for the job? Thanks.
unbob
#13 posted 03-28-2014 05:33 PM
Any small common sharpening stone should work fine. Just work the area that is effected, right on the edges of the gouges, it can be felt when using a stone when the burrs are knocked down.
Perhaps the above image will be of some comfort. The planer is a 16” out of a school. At some point, it appears a board with large nails or screws was run through it, leaving the pretty deep gouges. It works perfectly anyway.
ADHDan
#14 posted 03-28-2014 07:57 PM
Thanks! And yes, that’s exactly what my planer looks like. I wasn’t really concerned that the scratches would screw up the “flatness” of the beds for purposes of keeping boards parallel, I just don’t want to gouge my lumber. I’m glad to hear I’m not the first one with this experience.
TheWoodenOyster
1313 posts in 1902 days
#15 posted 03-28-2014 09:59 PM
I bet you can get it out with some sort of abrasive, whether it be files, stones, or sandpaper. I’d give it a whack. I would be surprised if the bed was ruined all together.
-- The Wood Is Your Oyster
