Anybody padded on water based poly?
Forum topic by Loren posted 03-28-2014 12:07 AM 964 views 0 times favorited 7 replies Add to Favorites Watch
View Loren's profile
10477 posts in 3766 days
03-28-2014 12:07 AM
When I first tried water based finishes on guitars I read the finish
could be padded on like shellac. I never tried it but I’m comfortable
padding shellac and I was wondering if it’s not worth the trouble
to try to get water based poly to do it.
I live in California and oil based finishes have become scarce. Otherwise
I’d mix up my own wiping varnish for this.
7 replies so far
View Monte Pittman's profile
Monte Pittman
29794 posts in 2456 days
#1 posted 03-28-2014 12:15 AM
Interesting. I never tried to thin it, but I would like to see your results if you do.
View gfadvm's profile
gfadvm
14940 posts in 2808 days
#2 posted 03-28-2014 12:28 AM
I’m watching this thread! I’m a big fan of padding shellac.
Monte Pittman
#3 posted 03-28-2014 09:02 AM
So Loren, are you thinking of doing it straight from the can, or thin it like a wipe on poly?
View Purrmaster's profile
Purrmaster
915 posts in 2211 days
#4 posted 03-28-2014 09:05 AM
Be careful about thinning it. From what I’ve read you can thin water base a little (with water) but not very much. Whereas you can thin oil base poly with mineral spirits almost as much as you like.
View upinflames's profile
upinflames
217 posts in 2280 days
#5 posted 03-28-2014 10:57 AM
You can thin WB poly as much as you like. If you mix it 75% water and 25% poly, you now have wood conditioner or “blotch control” instead of having to buy the stuff. Same thing for “wiping poly”, just thin down your WB or OB instead of buying all the crap people try to sell as wonder finish and such.
5069 posts in 2612 days
#6 posted 03-28-2014 11:19 AM
I don’t use much waterborne, but what I’ve read (Flexner, Jewitt) is pretty much what purrmaster said. The chemistry of waterborne finishes is quite a bit different than oil based, and thinning too much can be a problem. So at least test it before committing.
#7 posted 03-30-2014 05:32 PM
I’m doing a test piece and the result is promising. I’m using
an oil-modified waterborne finish.
