Leecraft Zc for Craftsman 113
Forum topic by ajthomas5009 posted 03-27-2014 10:05 PM 783 views 0 times favorited 3 replies Add to Favorites Watch
View ajthomas5009's profile
ajthomas5009
296 posts in 1494 days
03-27-2014 10:05 PM
Topic tags/keywords: tablesaw leecraft zero clearance craftsman zc
Im installing a cpl of zc inserts from Leecraft and am running into a little trouble. The blade is fully retracted of coarse. After spending about 30 mins adjusting the set and snugness screws the best I can get it to fit is ever so slightly proud towards the rear/sides and direct rear. Knowing the proper fit is either flush ever so slightly under flush I’m left kind of stumped.
Should I try sanding the ZC a little? Or do you think I probably need to switch to 7 1/4 in blade and step it up to 10 after starting?
Any suggestions?
Thanks
-- Sometimes you're flush and sometimes you're bust, and when you're up, it's never as good as it seems, and when you're down, you never think you'll be up again, but life goes on.
3 replies so far
View knotscott's profile
knotscott
7822 posts in 3252 days
#1 posted 03-27-2014 10:09 PM
If the insert is hitting a 10” blade, install a 7-1/4” and cut through it, then finish with the 10”. If it’s proud without interference from the blade, then you’ve got an issue with the insert.
View Jimbo4's profile
Jimbo4
1578 posts in 2639 days
#2 posted 03-28-2014 01:35 AM
I also have a Craftsman 113 – AND – have the same problem with the Leecraft ZC. Solution ?
-- When I was a kid I wanted to be older . . . . . this CRAP is not what I expected !
ajthomas5009
#3 posted 03-28-2014 02:01 AM
Thanks guys I figured it out. I had a feeling the 10” blade sits a little too high when bottomed out. It probably is because the Leecraft zci is really thick over the blade. Any how just throw in one 8” dado or 7 1/4 circular saw blade go up about an inch then throw on the 10” blade to complete the job. The zci was easy to level with the smaller blade on.
