Build a solar kiln or pay someone to dry wood
Forum topic by Doug posted 03-27-2014 09:33 PM 2844 views 0 times favorited 8 replies Add to Favorites Watch
View Doug's profile
Doug
18 posts in 1617 days
03-27-2014 09:33 PM
I have about 2,600 bdft of red oak and black cherry to be cut in the month or so.
I am considering building a solar kiln which will run between $1,200 and $1,600 excluding labor which I will provide.
Question is whether or not just to pay someone to dry the wood, or go ahead with building one.
Anyone have an idea of cost per bdft to dry oak and cherry?
Thanks, Doug
-- Doug
8 replies so far
View MisterBill's profile
MisterBill
411 posts in 2122 days
#1 posted 03-27-2014 10:16 PM
Well, will you continue to use the solar kiln in the years to come or is just a one shot deal?
View shipwright's profile
shipwright
7847 posts in 2668 days
#2 posted 03-27-2014 10:54 PM
You can build a solar kiln waaaaay cheaper than that.
Mine cost me some scrap OSB that was left over from a re-roofing, a little 6 mil plastic and the price of two cheap box fans and it works perfectly. It only does about 200 fbm at a time so yours would need to be bigger (or do several loads) but still you should be way down around a few hundred bucks …... unless you want it to be fully automated (unnecessary) pretty, and last a long time. Mine is about eight years old and is still operable. the only thing that goes is the plastic and it is cheap. It’s about five years old in the photos and all that is in it is a pile of stickers.
View Doug's profile
Doug
#3 posted 03-28-2014 01:06 AM
Mister Bill:
That would be an option to keep it and possibly rent it out, good possibility that I will sell our property (6 acres) and move south, so while I would like to keep it for future use, it may not work out that way.
Shipwright:
Looking for something to handle 2,000 bdft of lumber up to 11’ which i have a lot of at this time.
-- Doug
View Yonak's profile
Yonak
986 posts in 1391 days
#4 posted 03-28-2014 03:53 AM
Doug : ”...good possibility that I will sell our property (6 acres) and move…”
It sounds like you aren’t looking for a permanent structure, especially a dedicated permanent structure that would be an unlikely attraction for a future buyer . . .
Doug : “Looking for something to handle 2,000 bdft of lumber…”
. . . and yet you want a large capacity utility. Why not make something temporary that can handle small quantities and run several batches ? Something like Paul’s idea could be a temporary build or maybe a dehumidifier kiln. Here’s one reference : http://lumberjocks.com/topics/26879 An internet search reveals plenty of others. I know of people whose kiln is nothing but a sealed plastic wrap with a dehumidifier and a moisture meter inside.
shipwright
#5 posted 03-28-2014 04:17 AM
My kiln could easily be made larger with minimal extra cost. All you need is a solar collector (the plastic film) and a way to circulate the air. The rest is just an enclosure and a baffle or two.
This is the article that I based mine on. You can go more or less elaborate. Once you understand the principles involved, it becomes very simple.
View Doug's profile
Doug
#6 posted 03-28-2014 11:44 AM
Always options, time is the factor. If I build it will be on the order of a 8’ x 12’ unit that could be sold and moved easily.
One question not answered is what is the cost per bdft to have wood kiln dried.
No one in our areas is doing it, all the small mills are using air dry or selling green?
-- Doug
View Nomad62's profile
Nomad62
726 posts in 2828 days
#7 posted 03-28-2014 03:33 PM
I charge a buck a board foot, but I’m a ways away. But… the cost in kiln drying is often that of a less-than-knowledgeable kiln operator; a person can buy a kiln, puff their chest out and crow they have one to merely ruin everyone’s wood with improper procedures. So, it’s find someone who knows what they are doing or make your own kiln. If you make your own, you will study on how to get it right and you may get more for your dollar. My kiln can hold a charge of about 2000 bf, that is quite a stack of wood; I recommend make your floors and foundation accordingly, and best of luck to you.
View Doug's profile
Doug
#8 posted 03-28-2014 04:53 PM
Thank you, that was what I needed know. I have been studying it for about 3 years and am taking it serious about building it, and more so operating properly.
Virginia Tech has put out plans on one I would consider, and operation is something I am a concerned about as I want as high a yield from the process as possible.
Thanks again, Doug
-- Doug
