Bandsaw Blades - What to start with?
Forum topic by Kirk_T posted 03-27-2014 09:04 PM 1137 views 0 times favorited 6 replies Add to Favorites Watch
View Kirk_T's profile
Kirk_T
16 posts in 3218 days
03-27-2014 09:04 PM
Hi – I’ve been trying to make sense of all the blade options to get started with a new bandsaw, my Rikon 18” (10-345) was delivered today! I’m planning to cut logs, re-saw, cut out spoons and stool seats to start.
Was thinking of starting with the following? Is this a good place to start or would you recommend otherwise?
Logs and resaw work:
KERFMaster (http://www.spectrumsupply.com/kerfmaster-2.aspx) 3/4” x .022” x 3-4T
General cutting (spoons & stool seats):
Diamond (http://buyfromawoodworker.com/Diamond-Bandsaw-Blades_c10.htm) 3/8”x.032”x3TPI X-tra Duty
Do I also need a 1/4” blade as well?
Thanks,
-Kirk
-- -Kirk
View gfadvm's profile
gfadvm
14940 posts in 2560 days
#1 posted 03-28-2014 12:43 AM
I would recommend you get either Lonnie Bird’s or Mark Dujinski’s bandsaw book. Either will provide a lot of information re: which blades to use for each particular cut application.
View bonesbr549's profile
bonesbr549
1468 posts in 2937 days
#2 posted 03-28-2014 01:06 AM
you have an 18” bandsaw you have a lot of options. My first blades were timberwolf blades. They have a speical internet speical (if they still offer it) 4 for the price of 3. Also, nice was to call them and they will ask you questions and reccomend a blade. I got the 3tpi for resaw, a blade for green wood, and a 1/4” blade for tight cutting and something else, but I cant’ remember. I’ve sense, moved my big saw over to the laguna resaw king. Best blade ever used. Not cheap but you get what pay for. I’ve got 3 bandsaws now. I use a 14” with a small blade for the small stuff. Thats my opinion but that and a buck fifty will get you a cup of coffee. Have a good one.
View Jim Finn's profile
Jim Finn
2591 posts in 2792 days
#3 posted 03-28-2014 01:30 PM
I use my saw for re-sawing 99% of the time and found 5/8” 3 TPI carbide blades from Grizzly work great for this. Woodslicer blades are very sharp but dull quickly.
View pmayer's profile
pmayer
1013 posts in 2935 days
#4 posted 03-28-2014 01:51 PM
My favorite blade for resawing is the Laguna Resaw King. For all other cutting, I like Timberwolf blades (and they are great for resawing as well, but you just can’t beat the RK). They are one of the least expensive luxuries in woodworking.
As to your question of whether you need a 1/4” blade, it depends how much work you will be doing with tighter radius curves. I love using a 1/4” blade when the job calls for it. I also have an 1/8” blade that I pull out from time to time. I’d say if you have a 1/4” blade on hand you will probably use it occasionally.
Kirk_T
#5 posted 03-28-2014 02:38 PM
Thanks for the feedback everyone, I’ve also gone ahead and ordered Lonnie Bird’s bandsaw book!
-- -Kirk
View toolie's profile
toolie
2099 posts in 2498 days
#6 posted 03-29-2014 01:26 PM
hook up with lou iturra at iturra design. he’s probably forgotten more than bird and duginske will ever know about band saws and BS related products. and his catalog is like a BS primmer. great guy to deal with and his blade welds are as accurate as they come.
