Shop Vac Conversion
Forum topic by BuyoMasilla posted 03-27-2014 04:35 PM 4141 views 0 times favorited 15 replies Add to Favorites Watch
View BuyoMasilla's profile
BuyoMasilla
104 posts in 2786 days
03-27-2014 04:35 PM
Greetings,
I have a Ridgid bagless shop vac. The motor and intake hose are both on the top or motor part of the unit. It works fairly well, but the paper filters get soiled quickly.
I am wondering if anyone has taken one of these units and turned it into a bagged shop vac. Given the amount of creativity and skill found in this forum, I would not be surprised a bit if that were the case.
I think it’s this one; http://www.amazon.com/Ridgid-WD1250-Gallon-High-Performance-Vacuum/dp/B0029NY9W6
If the link works, you can tell there’s no hole in the side of the bucket for an intake where a bag could be mounted inside. It appears to be something that can be done and then find a way to plug the intake on top.
Anyone done this here? If you were to, how would you go about it?
Thanks!
-- Dreaming of the day I might joint two pieces of wood square..........
15 replies so far
View Gary's profile
Gary
9386 posts in 3672 days
#1 posted 03-27-2014 05:28 PM
I have one, larger than the one you posted. I merely blow the filter out and go again. I have taped a paper towel around the filter to prevent it from clogging up so soon.
Are you using it for general vacuuming or hooked up to a machine?
View The Box Whisperer's profile
The Box Whisperer
678 posts in 2309 days
#2 posted 03-27-2014 05:50 PM
I still dont use a bag, but I use the mid tier filter and a 5 gallon dust deputy on mine, it works pretty well.
-- "despite you best efforts and your confidence that your smarter and faster than a saw blade at 10k rpm…. your not …." - Charles Neil
View gtbuzz's profile
gtbuzz
427 posts in 2680 days
#3 posted 03-27-2014 06:28 PM
You could certainly do what you mentioned, but you may also want to look at some sort of pre-separator like a Dust Deputy or a DIY affair. That’ll keep the majority of the bulk from even reaching the filter in the first place.
I have the Rockler cyclone that I use with my Fein vac. It works well but I don’t really recommend it. It’s too prone to tipping.
View b2rtch's profile
b2rtch
4868 posts in 3287 days
#4 posted 03-27-2014 06:46 PM
BuyoMasilla,
Here is your solution:
I clean the filter inside may be once a year, probably less.
-- Bert
Shawn Masterson
1325 posts in 2187 days
#5 posted 03-27-2014 07:40 PM
This is the most compact version I’ve seen If you go to the clearvue photo gallery there are lots of set ups.
b2rtch
#6 posted 03-27-2014 07:55 PM
I wonder how the suction is on the most compact version, Certainly it looks good but there are many 90 degrees to reduce the suction.
-- Bert
View MrFid's profile
MrFid
888 posts in 2143 days
#7 posted 03-27-2014 08:15 PM
I’d invest in a Dust Deputy as well. Mine works great. Get a HEPA filter once you get the DD set up. There’s some good youtube videos on this topic as well. Good luck!
-- Bailey F - Eastern Mass.
BuyoMasilla
#8 posted 03-28-2014 02:31 AM
Thanks for the advice and comments everyone. Gary, I use it as a vacuum, it is not attached to any machine. The vacuum is used for cleaning up and we have been doing some tiling and laminate flooring so there has been a bit of demolition and much dust. The machine moves from the garage/shop to the inside of the house and having more “attachments” will make it more difficult to get it from one place to the other. If I’m able to convert it and fit it with a bag, then the portability and foot print remain as bad as the factory intended.
thanks again everyone.
View realcowtown_eric's profile
realcowtown_eric
617 posts in 2176 days
#9 posted 03-28-2014 04:22 AM
I’ve got several actual shop vacs. I won’t buy one that doesnt suck and blow .
I must confess I’m partial to the actual shop vac R2D2 versions, with the metal canister.
I typically discard the kludgy inflexible hoses and use he LV hoses with wands from household vacuum cleaners which I pick up at GSales.. That plastic crap )hoses, wands, etc is so frustrating, and breaks in the cold weather.
All the vacs I buy/ use are capable of being used with bag (except the little dewalt battery operated unit), and I generally discard the foam filter and opt for the general use or hepa pleated filter as case may require.
It was interesting to see the various mods/aumentations that folks have made.
Eric
These puppies are noisy, so I often times have them in another room and use a remote control to turn them on/off. AND, when you move them about, with a partially full bag, do check to see if the bag ain’t dislodged from the intake….it often does.
I’m not familiar with rigid products.
-- Real_cowtown_eric
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2608 days
#10 posted 03-28-2014 11:58 AM
I had one Rigid shop vac and I hated it. I bought it when we first bough our house for general cleanup (not woodworking). Suction sucked, in a bad way. I got the $20 Black Friday one. My guess is that this was their bottom-of-the-line model, and not indicative of their whole line. I gave it to a friend aand got the 6.5g Shop Vac and have been pleased. I use my Dust Deputy without a bag.
View Allen4's profile
Allen4
9 posts in 1761 days
#11 posted 03-28-2014 12:38 PM
I had an older model like what your talking about. Couldn’t get a bag for it. I tried putting old panty hose pieces over the filter. It works well with keeping the larger junk out. You can just wipe it off. I use my wet dry vac on machines so the saw dust clogs things fast.
I went ahead and bought the contractor grade rigid 6.5 hp. I have a preference for their wand which have something to grip over the Shop vacs. By the way never buy one that is a black Friday or clearance. Tried a shop vac at Lowe’s for $40-50. It went back the same day. They reverse manufacture them to still make money at that price, and you can tell.
Anyway, it’s quiet and takes bags. Built a Thien baffle cyclone to plug it into. Between the cyclone and the filter bag my HEPA filter doesn’t even discolor.
check out getting a new one or building a cyclone over buying one. I found for the cost of the dust deputy, I could just get a new shop vacuum.
View HorizontalMike's profile
HorizontalMike
7770 posts in 3153 days
#12 posted 03-28-2014 01:01 PM
FWIW, I built a separator for my 5gal shopvac and it works great! I even use a Hepafilter on the shopvac and really never need to clean it, the separator works that well. The lid is from Grizzly and I bought a 30gal can from HD.
You will also need to pick up a couple 4in to 2 1/2in hose adapters, but all above can be had for under $100 last time I checked.
View vacbag's profile
vacbag
1 post in 1167 days
#13 posted 11-10-2015 12:58 PM
@Buyo Masilla – Some ideas for your question re. Ridgid bagless to accepting bags …
https://www.youtube.com/watch?v=4iEvAZwlyew
https://www.youtube.com/watch?v=_24mlrlnDJo
View Kelly's profile
Kelly
2187 posts in 3183 days
#14 posted 11-10-2015 03:11 PM
I used my shop vac on the end of a Paint Shaver Pro and, quickly, found I had to come up with some sort of pre filter, since I only got a couple minutes run time before the vacuum efficiency dropped so bad I had to clean the filter.
First, I built my version of a Rainbow vac using a thirty gallon drum. It worked well, but, man, does old paint dust foam. Desperate for a better solution [than dealing with lead mud], I dropped a couple hundred on the Dust Deputy Bert mentions. I went the steel route, since it would get used on job sites.
The simple of it is, I now have three cyclones and refuse to even by a home vac, if it doesn’t spin debris out before it gets to the filter.
View clin's profile
clin
974 posts in 1235 days
#15 posted 11-10-2015 03:31 PM
To use that shop vac, a separator like a Dust Deputy would be the easiest solution, But that make the whole thing much more cumbersome to use as a portable vacuum.
If I were you, I’d just get a new vac that you can put a bag into and use a HEPA filter. Sounds like you’re doing some major remodeling. Perhaps another $100 for a new vac wouldn’t be a big deal.
Obviously you can just keep cleaning what you have, but a fine filter like a HEPA will plug fast and a not fine filter turns the vac into a dust pump.
-- Clin
