Pinching the blade during a crosscut?
Forum topic by erik25 posted 03-27-2014 06:07 AM 977 views 0 times favorited 3 replies Add to Favorites Watch
View erik25's profile
4 posts in 1529 days
03-27-2014 06:07 AM
Topic tags/keywords: cutting board cross cut wood technique binding internal stress blade question
I was making an end grain cutting board the other day, and when I went to cross cut the panel of laminated strips, the work piece started to pinch the blade very strongly. I’ve had a board start to pinch while I was ripping it, from the internal stresses, but I’ve never seen that during a cross cut. Can anyone explain what’s going on? It happened about 4 times, I was using a Freud combo blade, which was just cleaned, I first had the panel up against the fence, then I switched to a sled and still had the same problem. Thanks
3 replies so far
View Joseph Jossem's profile
Joseph Jossem
492 posts in 2203 days
#1 posted 03-27-2014 06:30 AM
alingment issues wrong blade bearings gone to fast to slow?
View Woodknack's profile
11311 posts in 2314 days
#2 posted 03-27-2014 07:40 AM
I don’t see how you can pinch in a crosscut. Just a guess but the blade was too low for the gullets to clear the waste and it just bogged down.
-- Rick M,
View jinkyjock's profile
488 posts in 1509 days
#3 posted 03-27-2014 10:04 AM
Same as Rick M. Do you have a riving knife fitted?, is it compatible with blade?.
