Drill Doctor or Not?
Forum topic by Sac posted 321 days ago 412 views 0 times favorited 14 replies Add to Favorites Watch
View Sac's profile
Sac
236 posts in 530 days
321 days ago
After reading all of the great responses about the WORKSHARP WS3000 here after Daniel's review I bought one and am awaiting it arrival with great anticipation. Now I look to add another sharpening tool for the drill bits. wood, metal and masonary. I wish the WS3000 came with an attachment and well for this. I have been eyeing the drill doctor but I am just not sold on it yet.
So what do you use to sharpen your bits? I am looking into attachment that may fit the grinding wheel But haven’t had the luck or confidence in what I have seen.
Thanks in advance for your responses.
-- Jerry, Set in the foothills of the Smokey's
20733 posts in 719 days
321 days ago
Jerry, I have both and, while I have extolled the virtues of the Worksharp many times, I have not have the same level of success with the Drill Doctor. I have found that I cannot sharpen bits below 7/64” because they are too short. When you mount the bit in the holder you have to manually turn it to get it aligned and I simply cannot reach the bit to turn it. And despite following the procedures in the booklet and video I simply have not gotten the edge on the bits I expected. And I have not been able to sharpen masonry bits at all. For me it seems to work best with bits between 1/8” and 1/4” inches, which is a very narrow range. I hope others have had better luck with their DD but for now I simply would rather get a new bit. The frustration and aggravation with using bits that aren’t sharp is not worth the hassle to me.
View Bob42's profile
Bob42
285 posts in 687 days
321 days ago
I too have the DD and have had similar problems. It seems to be very picky and I don’t get consistent results even when following the directions. I have not given up on it yet because sometimes I do get good results. I’m hoping it’s me and not the tool. I will continue to practice. I would also like to know if others are having a problem.
-- Bob K. East Northport, NY
View Sac's profile
Sac
321 days ago
Great comments Scott and Bob! Just what I was looking for. I’ve read alot of mixed reviews at other websites, ie: Amazon and eBay. I look to see more comments here. As a mentioned I am just not sold on the DD. Gut feeling seems to proving out with the first 2 responses.
View Steelmum's profile
Steelmum
347 posts in 859 days
321 days ago
Thanks! I have been considering it too. I think you saved me some time and money.
-- Berta in NC
View PurpLev's profile
PurpLev
2762 posts in 545 days
321 days ago
I have been using the Drill Doctor commercially when I was a contractor, and although the demos seem easy, and problems free, I’ve had poor results with the machine, and ended up getting a drill sharpener that I found at COSTCO for 1/4 of the price that does a great job in 1/2 the time the DD does.
the theory and mechanics behind the DD are terrific! but the actual results and performance are far from it.
Here is the one that I got
View gene's profile
gene
2165 posts in 780 days
320 days ago
DD is a tool that I had problems learning how to use also. I normally do not have a problem learning how to do something. However, the learning curve on this thing was really frustrating.The first couple of times I used it, the bits came out just awful. I put it on the shelf for about two years and finally got it out and made another attempt. After a while, I finally got the hang of it and now the results are pretty good. It took me a lot of practice. After I learned what to do, I sharpened about 75 bits over 2 days and they are all sharp. Not a dull bit in the house. Now, I can sharpen a bit in about 45 Seconds. This is not as easy as it looks on television, But after you get the hang of what to do, It works great. One thing that I did that helped me was to grind a bit that was very dull, down square on tip with the bench grinder and start over from scratch with the DD. Using equal amount of turns in the DD and not try to force or hurry the process. It is all about your wrist movement and using the same amount of pressure.You have to re-set the depth a few times to do this though. I have not used it on masonry bits so that could still be a problem.
-- Gene, a Christian in Virginia
View coloradoclimber's profile
coloradoclimber
448 posts in 965 days
320 days ago
hmm, I’ve been using the DD for a little over a year now, just on standard metal cutting twist bits, and I’ve had pretty good luck with it.
I’ve used it on bits from maybe 3/16 through 1/2 and found it to be little trouble to get an excellent edge. I did mess up the first once or twice until I figured out how the bit wants to be aligned when it’s clamped, after that pretty smooth sailing.
I find it quick enough to get a sharp edge that when I was drilling a stack of 1/4 inch diamond plate I stopped at about every plate and re-sharpened the bit. Drilling with a sharp bit is so much nicer than leaning on a bit that’s just spinning and burning.
I have not tried it on any bits other than standard twist bits. I dont know how it would perform on other types of bits.
View Sac's profile
Sac
320 days ago
Thanks folks. I like PurpLev’s. 1/10th the cost of a DD750. I took a look at one that Grizzley makes here. But in the meantime I think the one PurpLev is using is right up my alley. The plus side of it the wife just may go ahead and buy it since it comes with the ability to sharpen scissor’s :-D. Again thanks for the responses.
View CessnaPilotBarry's profile
CessnaPilotBarry
1285 posts in 599 days
320 days ago
I use twist drills very infrequently, as most of my work is with wood.
I either toss out dull smaller sizes, or sharpen the larger ones on the grinder with an angled fence. 95% of my drilling is with brad point or forstner bits, or the “nippled” Kreg bit. The DD doesn’t sharpen those.
Now, for a metalworker, the DD is great. My buddy has one and gets lots of use from it.
-- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply spit out the bait and ignore the thread...
View Sac's profile
Sac
315 days ago
Here is what I ended up getting. the cost was right and I figure I can’t loose to much with this product. The Grizzly G1081 Drill Sharpener.
View SteveKorz's profile
SteveKorz
2030 posts in 611 days
315 days ago
This has been an interesting thread… I need something BAD to sharpen my bits, I can’t do it free hand on the grinder. Well, I “can”, but I sharpen them like I used to do my pencils in grade school- all the way to the eraser… lol
Anyway, let me know how your device works, and how well you like it. My drill bits thank you.
Steve.
View northwoodsman's profile
northwoodsman
100 posts in 643 days
300 days ago
Woodcraft has both the 170 piece brad point and 170 piece twist drill bit sets on sale for $24.99 each. There are 19 sizes included and you get multiples of each. At this price, I wouldn’t even bother to sharpen them.
-- NorthWoodsMan
PurpLev
300 days ago
I got the 170 piece Brad Point set from Woodcraft, the metal is very soft that some of the bits will just BEND when you start rotating them in the drill, I was able to bend them back – BY HAND.
all in all -it’s 170 bits for $25 so I’m not complaining , def. good enough for my needs – but just be aware of their quality :)
View Kindlingmaker's profile
Kindlingmaker
1475 posts in 423 days
300 days ago
I too have bought these bits from WC and they seem better quality than the price they are being sold for but not as nice as the bits that are 100 times more expensive.
