Finishing trivets
Forum topic by daves1 posted 03-26-2014 10:26 PM 845 views 0 times favorited 3 replies Add to Favorites Watch
View daves1's profile
daves1
187 posts in 2736 days
03-26-2014 10:26 PM
Topic tags/keywords: trivets finishing question
I am making wooden trivets that I am spray painting. My question is, can a poly be put on to protect the finish from hot pans? If so should it be water based, can sprayed or something else?
3 replies so far
View TechTeacher04's profile
TechTeacher04
375 posts in 1501 days
#1 posted 03-27-2014 01:05 PM
Are you planning on painting them a solid color? if you why not use a high temp paint like the ones used for grills and engines. Once fully cured you will not have to worry about the heat or fumes. The paint is designed for heat applications. The high temp black I used on my tractor muffler can handle engine exhaust. Might be worth a try.
daves1
#2 posted 03-27-2014 01:39 PM
TechTeacher- yes a solid color- Pink as requested by my daughter. Not sure they make that kind in pink. Thanks for the suggestion
TechTeacher04
#3 posted 03-27-2014 04:23 PM
You might consider this, I made a set of trivets using ceramic tile and granite tile. Use either scrap trim or pieces you have milled to create a frame with a plywood bottom to support the tile. You can pick the tile based on color and finish the base as you wish. This way you do not have to worry about the hear. The ceramic tile will take that and more.
