Please recommend a fool-proof natural finish for cherry
Forum topic by HarveyDunn posted 03-26-2014 09:11 PM 1560 views 0 times favorited 19 replies Add to Favorites Watch
View HarveyDunn's profile
HarveyDunn
328 posts in 1605 days
03-26-2014 09:11 PM
I’m going to make a keepsake boxes out of some very nice QS cherry. I’d like a finish that makes the most of the the natural beauty of these boards. Could any recommend a fool-proof finishing schedule?
For what it is worth, these are the things I have on hand, but I’ll be happy to buy others if that is what it takes:
Watco Danish Oil (Natural)
Watco Clear Lacquer (Satin)
General Finishes Georgian Cherry Gel Stain
General Finishes Gel Topcoat Wipe on Urethane Satin
Shellac
Deft Nitrocellous Lacquer
Soft wax
19 replies so far
116811 posts in 3451 days
#1 posted 03-26-2014 09:14 PM
Sunlight and keep turning the boxes for a even tan. You can’t get more natural than that.
HarveyDunn
#2 posted 03-26-2014 09:45 PM
LOL – should have said “that I can do in one or two days”.
#3 posted 03-26-2014 10:05 PM
In bright sunlight you can do it in a day or two .Heres a way to do it in not such a natural way. Use Potaddium dichromate.
http://www.djmarks.com/stories/faq/where_can_i_get_potassium_dichromate_46686.asp
http://www.artchemicals.com/
HarveyDunn
#4 posted 03-26-2014 10:12 PM
Sorry, no.
View Tim Dahn's profile
Tim Dahn
1562 posts in 3439 days
#5 posted 03-26-2014 10:21 PM
Tried & True wood finishes
Recently started using it and like it.
View Michael J's profile
Michael J
103 posts in 3081 days
#6 posted 03-26-2014 10:56 PM
I’ve been using Watco Danish oil and Watco satin wax or Rennaissance paste wax on a lot of cherry furniture lately and I’ve been very happy with the results.
-- Mike Minneapolis, MN
View TerryDowning's profile
TerryDowning
1074 posts in 1991 days
#7 posted 03-26-2014 11:04 PM
This one is BLO and Mineral spirits 50/50 mix let dry overnight
finish with 4 coats of shellac and buffed with finishing wax
Click for details
This one is straight BLO with clear gloss lacquer rattle can
Click for details
Click for details
-- - Terry
View gfadvm's profile
gfadvm
14940 posts in 2564 days
#8 posted 03-27-2014 12:42 AM
Shellac rubbed on is the most foolproof finish I have found. And it works great on cherry.
Black Cherry has a blog on his technique and that is what I follow.
View Pezking7p's profile
Pezking7p
3217 posts in 1525 days
#9 posted 03-27-2014 01:19 AM
Danish oil is about as foolproof as it gets.
-- -Dan
View Monte Pittman's profile
Monte Pittman
27727 posts in 2212 days
#10 posted 03-27-2014 01:26 AM
Surefire perfect? That’s nearly impossible question. Too many variables. All of us have our own opinion of what the perfect look is. You have to find the formula that works for you.
-- Mother Nature created it, I just assemble it.
View WibblyPig's profile
WibblyPig
172 posts in 3148 days
#11 posted 03-27-2014 01:32 AM
1/3 BLO 1/3 Turpentine 1/3 Spar Varnish (NOT Spar Urethane). Wipe on, let sit for a little bit and wipe off. Build to desired sheen. Top off with carnuba wax.
A little hint, mix some mineral spirits in with your wax. It softens it up and makes it easier to apply (more like bee’s wax).
-- Steve, Webster Groves, MO "A society grows great when old men plant trees whose shade they know they shall never sit in."
View Purrmaster's profile
Purrmaster
915 posts in 1967 days
#12 posted 03-27-2014 01:33 AM
It depends on what you mean by foolproof. Cherry has a habit of blotching when you put finish on it. The least blotchy finish I ever got on cherry was using gel polyurethane. As to whether that looks natural enough is something of a matter of opinion.
I think boiled linseed oil would look ok. It won’t provide much protection though.
View CL810's profile
CL810
3719 posts in 2862 days
#13 posted 03-27-2014 02:08 AM
Harvey, I’m going to try to answer the question you asked. Forget the oils because they need more time then you have. Use the gel wipe-on poly you have.
-- "The only limits to our realization of tomorrow will be our doubts of today." - FDR
View levan's profile
levan
472 posts in 2853 days
#14 posted 03-27-2014 02:35 AM
I would suggest you do samples with the material you have, I’m sure one of them will meet your needs. My preference is Lacquer, no stains. Cherry will darken in time with the finish on it.
Best wishes
Lynn
-- "If you think you can do a thing or think you can't do a thing, you're right". Henry Ford
View woodchuckerNJ's profile
woodchuckerNJ
1251 posts in 1508 days
#15 posted 03-27-2014 03:05 AM
There is no FOOLPROOF method with Cherry. Cherry can and does unfortunately blotch.
That being said, there are lots of good recommendations above..
But nothing is absolutely foolproof. Like all blotchy woods it depends on the wood. Cherry blotches very easily.
Good luck.
-- Jeff NJ
