Cutting Board Juice Groove
Forum topic by Mr M's Woodshop posted 03-26-2014 04:38 PM 1618 views 0 times favorited 5 replies Add to Favorites Watch
View Mr M's Woodshop's profile
Mr M's Woodshop
420 posts in 3029 days
03-26-2014 04:38 PM
Topic tags/keywords: cutting board route
Cutting boards have become my new obsession. What is the best way to cut a juice groove around the edge of a board?
-- Henry Mowry, Santa Clarita, CA, http://www.MowryJournal.com
5 replies so far
View Mark828's profile
Mark828
95 posts in 1890 days
#1 posted 03-26-2014 04:56 PM
The way i cut the one in my most recent cutting board was with a 1/4 inch round nose bit and an edge guide on my router. This was my first attempt at a juice groove and i encountered a lot of burning which was fairly easy to sand out except for in the corners, that was a pain in the but and i could not find an effective way to sand the corners efficiently. If i could do it again i would probably take the time to cut out a template and use a guide insert instead. Id also play with different router speeds to try to reduce burning.
View Richard's profile
Richard
1916 posts in 2652 days
#2 posted 03-26-2014 05:05 PM
It looks like the Search Feature is working again so just type in Juice Groove there and you will get a lot of threads to check out. I just got 228 hits on it right now.
View JimRochester's profile
JimRochester
512 posts in 1576 days
#3 posted 03-30-2014 10:24 PM
Most seem to employ a template and a plunge router. I have always used the router table and a couple stop blocks. Still the same problems with burning but I’ve always been snake bit by the plunge router.
-- Schooled in the advanced art of sawdust and woodchip manufacturing.
View Paul Maurer's profile
Paul Maurer
162 posts in 1516 days
#4 posted 03-31-2014 04:03 AM
Plunge rout with a guide and template. Make several light passes- the deeper you get the lighter pass to take. Keep the router moving, don’t slow down- not even in the corners. Let the springs of your router pull the bit up from the work. Grind a scraper from an old saw blade or steel shim.
You do very nice work, I am surprised that you have asked, rather than answered this question.
Good luck
-- Psalm 62: 11 Once God has spoken; twice have I heard this: that power belongs to God, 12 and steadfast love belongs to you, O Lord. For you repay to all according to their work
View jmartel's profile
jmartel
7798 posts in 2112 days
#5 posted 03-31-2014 05:09 AM
I just use a straight edge guide on my router and take it slow.
