Shellac topcoat turning out uneven
Forum topic by HarveyDunn posted 03-26-2014 02:25 PM 1193 views 0 times favorited 9 replies Add to Favorites Watch
View HarveyDunn's profile
HarveyDunn
328 posts in 1973 days
03-26-2014 02:25 PM
I’m putting a shellac topcoat over milk paint. It is drying unevenly – it all looks fine when wet, but when it drys I can see ridges that look like a boundary marking an area where the shellac is thicker than it is in the neighboring area.
Any suggestions as to what I am doing wrong? Also, how to fix it – can I just sand it down and recoat?
9 replies so far
117423 posts in 3819 days
#1 posted 03-26-2014 02:40 PM
I don’t think milk paint and a alcohol base product is a good match. Shellac is a product that a new coat will melt into a existing coat ,so I would say apply another coat spraying it would be best,sanding is not necessary . If you have sprayed it already and you are not experienced spaying finishes that could be the reason your first coat looks uneven .
5244 posts in 2735 days
#2 posted 03-26-2014 03:36 PM
If you brushed that first coat on I would guess that’s the lap marks between brush strokes. If it’s a small area, you can scrape the excess shellac off with a utility knife blade, using it as a scraper. You could also just take a pad wetted with alcohol and smooth it out (I think). I’ve never tried (or heard of) shellac being applied over milk paint, so I’m unsure what would happen to the paint.
View gamygeezer's profile
gamygeezer
166 posts in 1827 days
#3 posted 03-26-2014 05:47 PM
I have had that problem when using angle-cut sash brushes for shellac. The shellac seems to flow towards the pointed tip of the brush and leaves more finish there. You might try “padding” it on, with a balled up wad of lint-free cotton cloth. I find that a much more satisfying finish. A thinner 1lb cut will also flow better, but needs more coats to look right. If you would rather use a brush, get a double tapered china bristle for the best results.
Ken
-- What's a vibrant young guy like me doing in a broken down old body like this?
View CharlesA's profile
CharlesA
3361 posts in 2039 days
#4 posted 03-26-2014 06:04 PM
What would be the purpose of shellac over paint? Wouldn’t bare paint be more durable? So a hard finish could make sense, perhaps. Maybe I’m just missing something.
View Clint Searl's profile
Clint Searl
1533 posts in 2603 days
#5 posted 03-26-2014 06:32 PM
Just top the shellac with a couple coats of waterborne poly. It’ll even things out. Then throw away the leftover shellac and never use it again.
HarveyDunn
#6 posted 03-26-2014 06:59 PM
Thanks everyone.
Charles, the purpose is:
1) deepens color
2) provides protection against fingerprints and waterspots. Not a lot of protection…but just enough for a light use item. Milk paint pretty much has to have a top coat of some sort.
CharlesA
#7 posted 03-26-2014 07:09 PM
Ok.
View AlaskaGuy's profile
AlaskaGuy
5005 posts in 2551 days
#8 posted 03-26-2014 07:10 PM
http://www.thebestthings.com/newtools/milk_paint.htm
CharlesA
#9 posted 03-26-2014 07:11 PM
Never would have figured that.
