fancy wooden swords
Forum topic by drpdrp posted 03-26-2014 01:34 AM 789 views 0 times favorited 5 replies Add to Favorites Watch
View drpdrp's profile
drpdrp
150 posts in 1954 days
03-26-2014 01:34 AM
I am going to make some “high end” wooden swords.
I am debating if the cross guard should be through mortised and then pegged in place- or made out of two pieces and sort of clamped around the tang.
Suggestions?
5 replies so far
View camps764's profile
camps764
867 posts in 2268 days
#1 posted 03-26-2014 01:36 AM
depends on how abused they will get I supposed. Clamped around the tang will probably get knocked loose and jiggle a little bit down the road. The through mortise wont.
-- Steve
View Mainiac Matt 's profile
Mainiac Matt
7673 posts in 2236 days
#2 posted 03-26-2014 01:38 AM
Katanas?
-- Pine is fine, but Oak's no joke!
drpdrp
#3 posted 03-26-2014 01:59 AM
They will be western style not katanas- at least not at this time.
I don’t suspect much abuse- the intention isn’t “practice swords” so much as cool geek props.
View Rick_M's profile
Rick_M
11133 posts in 2288 days
#4 posted 03-26-2014 06:15 AM
Through mortise from 2 pieces and put the glue line top and bottom, long grain to long grain. The convenience of 2 pieces with the strength of one.
-- http://thewoodknack.blogspot.com/
View The Box Whisperer's profile
The Box Whisperer
678 posts in 1978 days
#5 posted 03-26-2014 11:51 AM
I have several wooden swords from my kendo days. I will say that regardless of build if you can get a piece of iron wood some how use that. I have an old hand made iron wood katana, that I have used to break the manufactured oak ones in half. The thing barely has any dings, and Ive put it through the ropes. Good luck and please post a pic of whatever you end up using.
-- "despite you best efforts and your confidence that your smarter and faster than a saw blade at 10k rpm…. your not …." - Charles Neil
