Best thin wood for small outdoor sign?
Forum topic by nomercadies posted 03-25-2014 05:36 PM 2942 views 0 times favorited 11 replies Add to Favorites Watch
View nomercadies's profile
nomercadies
589 posts in 2243 days
03-25-2014 05:36 PM
Topic tags/keywords: resource question wood type adhesive
Our organization (http://chancefour.sharepoint.com) is putting together some items for a Butterfly Garden for a local library. We want to make small 3 inch by 5 inch signs for the individual plants that are to be planted there. A picture of what we are shooting for is attached. We are going to cut the stakes from a 2 by 4, but what thin wood could I use to make the sign part? Plywood that separates or wood that bends wouldn’t be the best example of our work or organization.
. I would also like ideas on how to attach the sign part to the stake. An adhesive would be great, but then again, the type of adhesive might depend on the materials used. This is the best place to get answers, and I surely need guidance.
-- Chance Four "Not Just a Second Chance"
11 replies so far
View Monte Pittman's profile
Monte Pittman
28157 posts in 2242 days
#1 posted 03-25-2014 05:45 PM
For what you are doing, any type of wood with the proper finish on it should work.
-- Mother Nature created it, I just assemble it.
View mahdee's profile
mahdee
3843 posts in 1671 days
#2 posted 03-25-2014 05:50 PM
nomercadies,
I also work with people with intellectual disabilities. You can use 2×6 instead. Cut 2-1/2” off it to make in into 2X3.
Slice the 2×3 into 2 or 3 and cut them at 5” lengths. The 2-1/2” piece should provide you with the stakes.
Use adhesive caulk or Gorilla glue to attach them.
-- earthartandfoods.com
View Underdog's profile
Underdog
1055 posts in 1939 days
#3 posted 03-25-2014 06:02 PM
For long term outdoor use, woods of choice would be:
Redwood
Cypress
Spanish Cedar
Locust
Osage Orange
Cedar
White Oak
For short term outdoor use, then just about anything will do.
As for the stakes and signs. you could also use your 2×4 (which are actually 1-1/2” x 3-1/2”) and just slice them into thin pieces 1/4” or 3/8” thick, then cross cut into 3-1/2”W x 5”L sections. You could continue to make your stakes of the same material.
-- "woodworker with an asterisk"
nomercadies
#4 posted 03-25-2014 07:00 PM
Thank you for the thoughts on how to re-saw dimensional lumber Mr. Jinx and U.D. I may re-saw some wood. I fear slicing even regular wood to expose different levels of moisture to the point of the finished piece warping on me. As I think of that and the environmental objections of anyone that would be putting in a butterfly garden, I rule out anything pressure treated. I also have terrible experiences with pressure treated lumber keeping its shape even if I don’t cut it. Thank you for a nice list Underdog. What finishes and procedures would you advise Mr. Pittman?
Everyone … Is there a plywood that would work, thin and relatively able to withstand the outdoors?
mahdee
#5 posted 03-25-2014 07:30 PM
Certainly treated wood is not for a garden of any kind. Cedar maybe your best bet ; no need to put a finish on it.
View Dallas's profile
Dallas
3599 posts in 2391 days
#6 posted 03-25-2014 07:34 PM
Don’t know of any plywood that will stand up long term.
My choice would be white cedar fence boards.
5/8” thick 5 1/2” wide, 6’ long.
Finish with poly or oil based enamel paint.
4873 posts in 2397 days
#7 posted 03-25-2014 07:36 PM
If you can use 1/2” thick material, Menard’s (I see you’re in Michigan) may have smaller pieces of MDO plywood. MDO is made for outdoor signs, so has good weather resistance and a very smooth surface made of some kind of fiber overlay. Paints well since that’s what it’s made to do and should serve you well. There may be some thinner, I’ve not seen it but I’ve bought some 1/2” at Menard’s…I think they may have it in cut down pieces, like 4’x4’.
View stnich's profile
stnich
118 posts in 2828 days
#8 posted 03-26-2014 12:39 PM
Why not use something like Azek. PVC sheets are available in many different thicknesses.
View Jim Jakosh's profile
Jim Jakosh
20071 posts in 3009 days
#9 posted 03-26-2014 06:18 PM
Cedar or white oak!!
View DrDirt's profile
DrDirt
4421 posts in 3646 days
#10 posted 03-26-2014 06:33 PM
I would use 3/8 marine plywood
For what you want to do it will be cheap and waterproof
nomercadies
#11 posted 03-27-2014 02:26 AM
Thank you all. I have many things to think about. Such a wealth of knowledge.
