Trouble Shooting Laguna H3 Edge Bander
Forum topic by Peter_Kasper posted 03-25-2014 03:51 PM 1123 views 0 times favorited 4 replies Add to Favorites Watch
View Peter_Kasper's profile
Peter_Kasper
1 post in 1760 days
03-25-2014 03:51 PM
Topic tags/keywords: refurbishing question modern
First time poster, go easy on me. I do mostly fine hardwood furniture, some cabinets-but this is a little beyond me.
I recently received a used automatic hot-air edgebander. It sat in storage for a number of years after the original owners passing. I’ve spent some time getting it back up and running and I have most of the issues worked out.
When I turn it on (set heat, trimming adjustments, etc.) the first one run is PERFECT. However, when the next one goes through, the tape that was about to go through has over heated. Hot glue runs everywhere, gums up the rollers & gears. As you can imagine its both messy and ineffective to stop, clean out the glue & tape bits.
I have tried turning the heat down to different settings. I either get the same mess, or the the tape is not heated enough to secure to the board.
I’ve tried running different tape (perhaps the tape is too old?) with similar results.
Parts diagrams show I have everything in order, trouble shooting manual doesn’t seem to cover it. I have heard the Laguna customer care can be hit or miss.
Anyone have experience with this machine, or know a shop that uses one?
I’ve played with it over the last 2-3 months, its not part of my main business so I haven’t worried about it too much. Will post pics soon.
Thank you for your time, I look forward to this community.
-PK
117417 posts in 3814 days
#1 posted 03-25-2014 03:58 PM
Perhaps a Laguna tech can help?
View Loren's profile
10477 posts in 3884 days
#2 posted 03-25-2014 04:03 PM
Edgebanders are fussy machines. Yours is on the less-complicated
end of the spectrum. In any case, I would definitely recommend
you get some brand new edgebanding if all you have is old
stuff.
View crank49's profile
crank49
4032 posts in 3208 days
#3 posted 03-25-2014 06:08 PM
I would have no trouble shooting one of those.
Might chose to use a shotgun since a rifle slug could ricochet.
#4 posted 03-25-2014 06:40 PM
