Using hardboard to make boxes?
Forum topic by InstantSiv posted 03-25-2014 04:25 AM 3912 views 1 time favorited 5 replies Add to Favorites Watch
View InstantSiv's profile
InstantSiv
262 posts in 1591 days
03-25-2014 04:25 AM
Hi, I need to make simple 5 sided boxes for organization around the shop. I haven’t seen much information about this in my research.
-Is there a proven way to make hardboard boxes?
-Will wood glue work gluing hardboard to hardboard?
-Will wood glue work on the tempered side?
-If wood glue won’t work on the tempered side what will?
Thank you
5 replies so far
View NiteWalker's profile
NiteWalker
2737 posts in 2573 days
#1 posted 03-25-2014 09:07 AM
Hardboard is kind of flimsy for shop storage. If you mean hardware storage bins, 1/4” baltic birch plywood would be a LOT better. Box joints or a tongue and dado joint would be my choices.
View Minorhero's profile
Minorhero
373 posts in 2601 days
#2 posted 03-25-2014 11:34 AM
I am sure it is cheap, but I wouldn’t want to trust it with anything heavy.
http://www.instructables.com/id/Hardboard-tool-crate/
View Jim Finn's profile
Jim Finn
2656 posts in 2918 days
#3 posted 03-25-2014 12:19 PM
If you do it with hardboard I would put 1”x1” pine in each corner to glue and nail it to.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
View dstutz's profile
dstutz
7 posts in 1588 days
#4 posted 03-25-2014 01:24 PM
I made some simple shop drawers with 1×4 pine and used hardboard for the bottoms. These 2 smaller ones are using 1/4” hardboard and I store my router stuff in one and drill press stuff in another and it’s plenty strong at this smaller size (Speed square for scale).
As an alternative, Here are instructions for making stackable boxes out plywood
View hobby1's profile
hobby1
335 posts in 2294 days
#5 posted 03-25-2014 01:37 PM
One of your questions were:
Yes, it can b e done, the sure way to have a sturdy box made with the thin material, is to use hardwood (pine) strips of around 1 1/2” wide, by 3/4” thick glued and tacked to all three ends (back, front, and bottom) of both side panels of the box then join the bottom panel and the back and front panel to these side panels by glueing and tacking them to the hardwood strips
The bottom can be made more secure by putting the bottom panel ontop of the bottom strip to give better support.
