Dovetails - Coping, Fret, or Conventional Saw
« back to Joinery forum
Forum topic by EKG posted 03-25-2014 12:10 AM 1382 views 0 times favorited 15 replies Add to Favorites Watch
View EKG's profile
EKG
11 posts in 1548 days
03-25-2014 12:10 AM
I’m, building a workbench. The legs are 4×4 cedar. I cutting a dovetail tenon in each one. My J&S and Japanese saws are horrible. Any thoughts on using a buck saw, or, fret or coping saw to cut these?
Regards,
EKG
-- Eric G.
15 replies so far
View redSLED's profile
redSLED
790 posts in 1886 days
#1 posted 03-25-2014 12:58 AM
Though theoretically one can do it, I will rule out your coping saw for you.
You could also drill out holes to the right depths and chisel out your tenons.
TopamaxSurvivor
18266 posts in 3670 days
#2 posted 03-25-2014 05:29 AM
Are you cutting a dovetail on cedar?
View Loren's profile
10373 posts in 3642 days
#3 posted 03-25-2014 05:37 AM
Japanese saws may be slow, but they tend to be accurate
due to the minimal set.
Your best dovetailing or tenon saw has a rip tooth pattern
and minimal set. Almost nothing off the shelf comes this
way.
I cut all but the smallest dovetails using a shop-made bow saw
with a 22” butcher-saw blade with the set nearly stoned
away and the teeth refiled to rip. It tracks unbelievably
well and I have to wax it so it doesn’t bind in the kerf -
that’s how little set there is left. You could make your own
for about $10 for the blade and using odds and ends
on hand.
A ryoba would do the job though. I like the Gyocucho ryoba
with the cane-wrapped handle…. $38 from Woodcraft these
days. I won’t vouch for any Japanese saw with a plastic
handle as I’ve used some that feel just terrible compared
to the heavier wood-handled ones.
View Purrmaster's profile
Purrmaster
915 posts in 2087 days
#4 posted 03-25-2014 07:20 AM
To cut out the waste I prefer a fret saw.
View theoldfart's profile
theoldfart
9694 posts in 2445 days
#5 posted 03-25-2014 11:50 AM
If you are doing big dovetails for a bench i would use a large dovetail to start the cuts and finish with a mitre saw
Chop the waste with a mortis chisel or a heavy duty bench chisel
Cutting the waste with a saw on large scale work is slow
-- "With every tool obtained, there is another that is needed" DonW ( Kevin )
View EKG's profile
EKG
#6 posted 03-26-2014 08:26 PM
Thanks oldfarrt – you gave me a whole new perspective.
-- Eric G.
View EKG's profile
EKG
#7 posted 03-26-2014 11:27 PM
Hi Kevin:
I’ve tried two Japanese saws:
Carpenter’s Saw – 12” Double Edge (Ryoba) RazorSaw
Crosscut Saw w/thicker blade RazorSaw – a single edged saw)
and a Jackson & Spears 15 TPI tenon saw). I’ve read all the techniques as how to use them, and they all bind. When I start the cut again, the saws like to find a new position and not follow the scribed line.
They cut fine on a perpendicular cut, but not at an angle, like you would for a dovetail.
Apparently I don’t know how to use them properly, or, I have the wrong saws.
In each case, I scribe a line, and cut on the inside of the scribe. I do not use excessive force, and take my time.
These are new saws, and have never been used before (except for me for practice).
-- Eric G.
theoldfart
#8 posted 03-26-2014 11:59 PM
Eric, I don’t have an answer for you. I had some of the same issues and just practiced for some time. My dovetail saw has been professionally sharpened by Matt Cianci and that improved my sawing a bit.
Try looking at some Chris Schwarz’s videos, I’ve had good luck with his techniques.
Whatever you do don’t give up, it will happen for you. I was pretty certain when I started that all I needed was good tools; learned quickly that experience and skill can make most tools work better.
View EKG's profile
EKG
#9 posted 03-27-2014 12:26 AM
Hi Kevin: I think you hit the nail on the head – practice, and practice. I read one site where the commentator said you should cut one dovetail a day, every day, until you get it right. I think I’m in full concurrence with his suggestion.
-- Eric G.
View EKG's profile
EKG
#10 posted 03-27-2014 02:01 AM
TopamaxSurvivor: Yes cedar – it’s cheap & I think 4×4 legs should be robust, given my table top will be 2×4’s on end. Each leg will have a large dovetail – just an experiment.
-- Eric G.
TopamaxSurvivor
#11 posted 03-27-2014 02:34 AM
I wonder if cedar will be strong enough to hold a dovetail joint. I might just split with the stress??
View EKG's profile
EKG
#12 posted 03-27-2014 02:49 AM
TopamaxSurvivor: You’re right – just an experiment to see if I could do 3 1/2” dovetails properly. If it doesn’t work, a hardwood will be selected for the legs. Any suggestions on a reasonably priced hardwood?
Anyways, the tabletop will be 2×4’s on end, so the depth of the tabletop will be 3 1/2”. The top will be 96” x 36”.
Thanks
-- Eric G.
TopamaxSurvivor
#13 posted 03-27-2014 02:54 AM
Any suggestions on a reasonably priced hardwood? Find a local sawyer is my best guess.
View EKG's profile
EKG
#14 posted 03-27-2014 03:09 AM
TopamaxSurvivor: Just a thought – what about glued & screwed plywood, which is is stronger than any hardwood (I think). It is glued in perpendicular sheets, which is indestructible. A glued 4×4 plywood leg would be indestructible, and carry a decent weight. High Density Fibre (HDF), or even MDF might be another option.
Some more of your good thoughts pls.
-- Eric G.
TopamaxSurvivor
#15 posted 03-27-2014 04:32 AM
Lots of people more qualified than I to answer those questions. Check out Shipwright’s bench here: http://lumberjocks.com/projects/93097 He used plywood to make legs.
