Mikta 2401B Miter Saw - Fix
Forum topic by DangerDoug posted 03-24-2014 09:05 AM 882 views 0 times favorited 8 replies Add to Favorites Watch
View DangerDoug's profile
DangerDoug
72 posts in 1610 days
03-24-2014 09:05 AM
Have an old Mikta 2401B, it’s in great shape but has had a problem for a long time.
It will grab pieces and throw them around the room, I got used to that but thinking may be a good time to fix.
Any ideas?
Could the fence be bent? it’s cast iron, so that’s hard to believe.
Blade wobble? I can’t really see any, can see a little wobble with a cheapy blade.
The saw works a little better with a good blade, but it will still grab small cutoffs.
My friend is starting a molding project, I can’t lend this to them – as is.
8 replies so far
View lateralus819's profile
lateralus819
2241 posts in 1853 days
#1 posted 03-24-2014 09:25 AM
Is a new blade? Cupped or twisted wood? The only time I’ve ever had a miter saw grab is if the wood is twisted.
Curious if the arbor is bent.
DangerDoug
#2 posted 03-24-2014 09:30 AM
Well this has been a problem for years, and got really good at ducking.
Had all kinds of material on there and blades too.
Yes, maybe the arbor :-/
View Tony_S's profile
Tony_S
857 posts in 3047 days
#3 posted 03-24-2014 09:58 AM
Check the fence with an accurate straight edge. I’d bet that it’s bent.
-- It is the mark of an educated mind to be able to entertain a thought without accepting it. Aristotle
View shopdog's profile
shopdog
577 posts in 3449 days
#4 posted 03-24-2014 03:23 PM
is the blade in backwards?
had to ask…
-- Steve-- http://www.urbanexteriors.biz
DangerDoug
#5 posted 03-25-2014 08:59 AM
hahaha no-no think we got that in the right direction.
Okay, the fence is out about 2.5 pieces of paper i.e. 10 thousands (pinched in).
Guessing the fence is Alum. What to do – pull it off and sand/plane it straight?
Could bolt a back board/fence and run through planer, but that would mess with the capacity.
The max now is about a 3.5” x 3.5”, so not much.
View dhazelton's profile
dhazelton
2754 posts in 2260 days
#6 posted 03-25-2014 12:16 PM
What kind of blade do you use? If one with too few teeth and a large hook angle it will do that.
DangerDoug
#7 posted 03-26-2014 08:55 AM
Using a 60 tooth “plastic” blade now – which works the best.
I’m thinking the saw might have more than one thing wrong, to make the small pieces “walk” e.g. vibration.
I guess there are a few options about the fence.
>Make a fence from Alum angle or 6/4 stock
>cut/notch the back in “C” section of fence and reinstall straight
>order new part – from Replacement Part.
DangerDoug
#8 posted 03-30-2014 09:03 PM
Maybe too much fusing and not enough looking—
There was a lot of blade wobble; but arbor was not bent.
The arbor assemble pops out in a jiff btw – took it out and cleaned/oiled it.
Turns out the 2 large washers that hold the blade are twisted up. I had other washer/caps from other old equipment stashed away – with a little effort was able to install them and the blade runs straight and true now.
This “chop saw” is nicely designed, easy to work on.
