Unusual issue with Forrest WWII 20T rib blade
Forum topic by bonesbr549 posted 03-23-2014 02:39 AM 1005 views 0 times favorited 5 replies Add to Favorites Watch
View bonesbr549's profile
bonesbr549
1533 posts in 3037 days
03-23-2014 02:39 AM
Ok, I’ve been a huge fan of Forrest blades forever. Always wanted a rip blade and finally bit the bullet and bought one. Was using this evening and testing it out. Right off the bat had an issue. I have a sawstop and you need to set the cartridge away from the blade the width of a nickle. When I swapped out the standard blade with the WWII 20T got an error code and when I checked the blade was 9 7/8”. Any body out there got one of these blades? If so, is your 10” blade not 10”? I’m thinking it’s a stinker and needs replacing.
5 replies so far
View knotscott's profile
knotscott
7985 posts in 3345 days
#1 posted 03-23-2014 11:21 AM
I’ve never checked the diameter of my blades, but I’ve read that some 10” Freud blades are slightly less than 10”....could be true of several brands. The odds of Forrest unintentionally making a blade 9-7/8” diameter seems remote to me….lots of other little things can happen by mistake, but that may be the diameter the blades are specified to be. Call Forrest and ask.
View buildingmonkey's profile
buildingmonkey
242 posts in 1517 days
#2 posted 03-23-2014 01:49 PM
The 250mm blades the euros sell are about 9 7/8”, just bought a couple for my new Hammer saw. These companies are most likely going to metric sized blades.
-- Jim from Kansas
View MrRon's profile
MrRon
4722 posts in 3213 days
#3 posted 03-23-2014 05:40 PM
I think blade diameters are probably “nominal”; that is ± a few thousands. I don’t think it’s anything to be concerned about.
View woodchuckerNJ's profile
woodchuckerNJ
1269 posts in 1604 days
#4 posted 03-23-2014 05:51 PM
Give them a call tomorrow, speak with Tony
-- Jeff NJ
View bowedcurly's profile
bowedcurly
519 posts in 1699 days
#5 posted 03-23-2014 06:47 PM
I don’t know what size or dia mine is but it rips the hell outta anything that stands in it’s way, the best by far rip blade I ever used, I hope you get to put it to use it rips wood like butter…...
-- Staining killed the wood<<<<<>>>>>Dyeing gave it life
