Freud LM75R010 10" Thin Kerf Glue Line Rip Blade is out by .017 - is this normal?
Forum topic by Jerry posted 03-23-2014 12:57 AM 1805 views 0 times favorited 18 replies Add to Favorites Watch
View Jerry's profile
Jerry
2635 posts in 1647 days
03-23-2014 12:57 AM
Topic tags/keywords: question tablesaw saw blade
Some of you may have seen my review of the “Freud LM75R010 10 Thin Kerf Glue Line Rip Blade a couple of days ago. Today, when I was putting the crosscut sled back on and lining it up ( I have a shopsmith, so the table moves too, hence the need to line up ) I noticed I was having a real hard time, so I got up close and personal, and eyeballed the blade in the kerf slot of the sled at the very end, turning the blade by hand, I noticed that the blade seemed to be oscillating from side to side in the slot. I figured it may be the blade, or it may be the shopsmith. Knowing that I had recently restored the shopsmith and it had less than 10 hours on all new bearings, I suspected the blade. I attached a dial indicator to a magnetic stand and attached the stand to the round tubes of the shopsmith. I zeroed the dial indicator, and rotated the blade by hand ( not touching the blade, using the rear output shaft for the jointer to rotate it. ) The dial indicator showed the Freud blade to be out a maximum of .017. I then put a 20 year old Makita blade on the shopsmith and conducted the same test. The makita blade was out a maximum of .006. Should I take this blade back, or is this acceptable deviation?
-- There are good ships and there are wood ships, the ships that sail the sea, but the best ships are friendships and may they always be. http://www.geraldlhunsucker.com/
18 replies so far
View MrUnix's profile
MrUnix
6715 posts in 2198 days
#1 posted 03-23-2014 01:17 AM
This is the magic bullet. No burning, No resistance smooth smooth smooth cutting!!!!
It apparently doesn’t make much difference in performance based on your comment.
View woodchuckerNJ's profile
woodchuckerNJ
1274 posts in 1633 days
#2 posted 03-23-2014 01:37 AM
It’s not normal.
Thin kerf blades bend easily. My Forrest bent, when they sharpened it, I had them straighten the plate.
Give Freud a call or send them an email. They are a very good company.
-- Jeff NJ
Jerry
#3 posted 03-23-2014 01:46 AM
Brad, I agree to a point, but consider the fact that it’s always going to be cutting a wider kerf than it should.
Jerry
#4 posted 03-23-2014 01:48 AM
Jeff, that is what I thought given the fact that this blade has only made 4 “clean up the edge” cuts in birch plywood since it was new, I don’t believe it bent on my table saw, I think it came to me that way.
View Nicky's profile
Nicky
695 posts in 4091 days
#5 posted 03-23-2014 01:51 AM
It’s not normal as woodcheck said.
This is on my saw now, dial indicates about .003. Not sure about specs, but a few thou would be respectable. .017 is a bit much for me. If it’s new, take it back.
-- Nicky
View lanwater's profile
lanwater
3111 posts in 2933 days
#6 posted 03-23-2014 08:14 AM
I just got mine today and have not installed it yet…
.017 is too much anything more than 0.005 I was taught is too much
-- Abbas, Castro Valley, CA
View Roger's profile
Roger
20928 posts in 2803 days
#7 posted 03-23-2014 11:05 AM
One of those stabilizer washers may help some. Freud SC-001 3-1/2-Inch Blade Stabilizer with 5/8-Inch Arbor for 7-Inch Saws or Larger
View knotscott's profile
knotscott
8015 posts in 3375 days
#8 posted 03-23-2014 11:30 AM
It should be better than that, but unless it’s notably effecting performance, I’m not sure I’d do anything about it.
View MrRon's profile
MrRon
4770 posts in 3243 days
#9 posted 03-23-2014 05:44 PM
.017” is way too much. The best blades like Tenyru and Everlast deviate about .002”. Does your saw use the 1-1/4” arbor?
View Gene Howe's profile
Gene Howe
10479 posts in 3428 days
#10 posted 03-23-2014 05:53 PM
Jerry,
I use Tenryus and see the same thing, but only on startup. When I reach saw/joint speed it seems to straighten out.
Jerry
#11 posted 03-23-2014 06:33 PM
My saw uses an adapter to bring it down to a standard 5/8” arbor. As far as whether the blade straightens out at speed, I can’t think of a safe way to measure that, and I don’t think eyeballing it would do me any good since the blade would obviously appear to be straight at high rpms because of persistence of vision.
Jerry
#12 posted 03-23-2014 06:42 PM
Okay, after doing a search on the phrase ” freud saw blade runout” I came across this article
http://www.woodtechtooling.com/FreudTooling/CommercialSawblades/ToolTips/FreudSawBladep11.html#Tips
Apparently the arbor flanges need to be at least 1/3 the diameter of the blade, so in my case, at least 3.3” I’ve never seen flanges that large, does anyone use flanges that large?
Gene Howe
#13 posted 03-23-2014 06:46 PM
Jerry, the way I checked mine was to make a partial cut and measure the kerf against the blade’s width, by sliding it back on to the blade. Looked good to me. You might try that and use a dial caliper to verify. I’ve never gone to that extent.
edit: Freud makes a disk that is 3.5” in dia. Peachtree sells it.
Jerry
#14 posted 03-23-2014 07:10 PM
Gene that is extremely helpful, thanks a lot!
Shawn Masterson
1325 posts in 1948 days
#15 posted 03-23-2014 11:19 PM
you have to watch the stabilizer disk. The size may hit the insert when you take the blade all the way up. I do this when I resaw at the TS.
