Tire Mastic and Bearing Shaft
Forum topic by Charlie75 posted 03-22-2014 02:20 PM 904 views 1 time favorited 9 replies Add to Favorites Watch
View Charlie75's profile
Charlie75
310 posts in 2174 days
03-22-2014 02:20 PM
I was going to clean up one of the wheels on my band saw to put a new tire on. This old tire was glued on by the PO and after I removed the old tire this mess was left behind. Seems like I have read somewhere that there is something that will dissolve this stuff. Here are a couple of photos:
While I am on here someone either on here or another forum asked me to put up a couple of photos that I am having trouble removing the bearing from. Also someone suggested I try to remove this bearing from the opposit end. Looking at the photo you can see that is not possible.
This photo is an attempt to show the damage to the threads.
Charlie
-- Charlie75, Alto
9 replies so far
View Newbiewoodworker43's profile
Newbiewoodworker43
150 posts in 2351 days
#1 posted 03-22-2014 02:52 PM
Hey Charlie, When I removed the tires from my BS they looked pretty much the same as yours. I ended up taking a chisel and very carefully scraping off all the residue. I then took steel wool and cleaned it the rest of the way. It took quite some time and efforts but at the end of the process everything looked great. I also took special care not to damage the crowning on the wheel.
Probably there is a more elegant way to do this but that is what I did.
The Ultra Max Urethane tires that I put on afterwards work great. They are very thick and the blade I am using tracks great on them. I did not glue them down as that is not necessarily required although I have read several posts where people recommend gluing them down.
-- ---Howard, Amesbury MA
View tyvekboy's profile
tyvekboy
1724 posts in 2922 days
#2 posted 03-22-2014 03:12 PM
I usually try a heat gun to soften up glue or adhesive and usually it easily scrapes off. Since wheel is metal, this option should work.
-- Tyvekboy -- Marietta, GA ………….. one can never be too organized
Charlie75
#3 posted 03-22-2014 05:22 PM
Thanks to both of you. I was working on the wheel with an old chisel but thought there might be an easier way. I will try the heat gun approach.
I got the Ultra Max Urethane tires also. Fortunately I only have to clean one wheel. The other one is brand new a short time ago according to the PO. The tire on that one came off and there was no mastic used.
By the way, I got the bearing off this morning. I had to use a bearing puller. Forgot that I had that tool.
Charlie
-- Charlie75, Alto
View gfadvm's profile
gfadvm
14940 posts in 2599 days
#4 posted 03-23-2014 12:39 AM
3 thoughts on removing that glue mess: mineral spirits, lacquer thinner, or heat gun. I would try em in that order.
Charlie75
#5 posted 03-23-2014 01:09 AM
gfadvm, Thanks. I will do just that. I did try paint thinner. Didn’t work.
Charlie
-- Charlie75, Alto
View MrUnix's profile
MrUnix
6373 posts in 2108 days
#6 posted 03-23-2014 01:24 AM
Try WD-40 and a putty knife.
View TheGermanJoiner's profile
TheGermanJoiner
847 posts in 1546 days
#7 posted 03-23-2014 01:26 AM
Goo gone is pretty magical stuff. You can get it at big blue or orange
-- Greg - Ferdinand and Son Construction: Do it right the first time. Like us on Facebook
View Bluepine38's profile
Bluepine38
3379 posts in 2994 days
#8 posted 03-23-2014 07:02 PM
I keep a can of 3M adhesive remover in my shop for little chores like that. It removes most adhesives without
any problem.
Charlie75
#9 posted 03-24-2014 12:17 PM
Thanks for all the great tips folks. I will be trying some of them.
Charlie
-- Charlie75, Alto
